Page 2 of 16 FirstFirst 1 2 3 4 12 ... LastLast
Results 11 to 20 of 157
    Re: Project log, New SXR from Sinister Sand Sports....
    Sick work Yoshi it really does look Sinister!!!
    Oct 2008
    Ontario, Canada
    Wow... that jig is impressive!
    Sep 2008
    Allendale MI
    Finally the Subi motor eh....
    Very nice!
    Justin
    Nowhere near the desert.
    Quote Originally Posted by N8ball View Post
    Top shelf Yoshi, as always.
    Do you build the first frame free style, then build the jig to match or start with the jig?
    Yerp. Then I have to make some minor tweaking to the blue prints for the first 2 or 3, then the pieces fit nicely into the jig from then on....
    www.SinisterSandSports.com
    918-521-3736
    Full bump (5" clearance rear, 6" clearance front)
    Full extension (25"+ clearance) although I did a little tweaking to the shock mounts to get it to 26" in the front after the pic.
    918-521-3736
    Apr 2007
    Riverside, CA.
    Very cool Yoshi.
    WOW! that looks awesome.
    And a pic of the new seating position and head clearance, which is a lot more comfortable. I'm just under 6'2", 170 pounds, and the pedals still go about 2" farther forward than in the picture, which were already about 2" farther than what I would have them set at for me.........
    918-521-3736
    And the amount of wider protective space between the occupants and the outside frame rails...
    918-521-3736
    Quote Originally Posted by yoshi View Post
    before I changed the lower a-arm, how it will look with a subi setup, how the subframe comes out......
    So do you have 4-5 bolts per side at the mid-point and then 1 bolt per side at the front on that subframe? I want to do a subframe in my buggy but haven't seen any clear pictures or thoughts on how/what to do. Got any insight?
    BTW, the car looks great as usual.
  1. Project Logs
    Last Post: 05-21-2005, 05:41 AM
