Results 1 to 8 of 8
    Convert quad spindles question.
    Dec 2015
    Near Pittsburgh, PA
    I bought Raptor spindles for my Shredder hybrid. I was able to get the hubs, rotors and calipers...which I thought would be a good way to go.
    After getting the plans I see how the Raptor spindles have the geometry all wrong.
    I have an idea of what I want to do.
    The snout? looked like it could press out so I tried it:
    Easy to get apart with my Harbor Frieght press:
    Plan is to cut off the excess and leave the caliper mounts:
    The snout is metal, so I plan on building the spindle part according to the SII plans, but welding the Raptor piece on instead of the 5" bolt the plans call for.
    The plans call for 1" OD DOM with 3/4"ID.
    Is there any square tube that would be an equal to that? I was just thinking that it would be nicer to weld the snout to a flat surface.
    DARWIN did the same thing basically but he made up all the parts whereas I just want to do a simple hack to the Yamaha parts.
    Pic is Darwins:
    Re: Convert quad spindles question.
    Senior Member Jerm's Avatar
    Dec 2013
    Ontario Canada
    Its too bad you already cut it up. If you had the matching arms that go with those spindles, then just bolt up the entire arm and spindle assembly. Thats what I did but I used YFZ450 arms and spindles.
    Dec 2015
    Near Pittsburgh, PA
    No arms and already started building the Shredder arms so all is good there.
    Wondering about the square tube though.
    Dec 2015
    Near Pittsburgh, PA
    After seeing more styles of spindles, I really want to build one that is double sheared. If I understand the term correctly.
    I ordered high misalignment heims to use instead of the balljoints the plans call for...was just going to bolt them down like the balljoints but then I saw the more proper way to build them.
    I was thinking either square tube or a C channel and then mount the heims vertically.
    I think they would work as the one has 64 of misalignment and the other 61.
    Can anyone verify that it would work or does that only work when you take a normal heim and add the spacers?
    These are what I ordered:
    QA1 PCY Series Rod Ends PCYMR12T - Free Shipping on Orders Over $99 at Summit Racing
    QA1 PCY Series Rod Ends PCYMR10T - Free Shipping on Orders Over $99 at Summit Racing
    Jan 2012
    SLC, UT
    I havent had problems with the square tube arms. The raptor spindles would have saved a lot of fab time.
    Dec 2015
    Near Pittsburgh, PA
    Quote Originally Posted by Lug-Nuts View Post
    I think I am going to check out some square tube for the spindles instead of the round the plans call for...flat surface to tack the Raptor snout to.
    I could also make them in plate if I turn the heims vertical and make them double shear easier.
    Jan 2012
    SLC, UT
    Dec 2015
    Near Pittsburgh, PA
    I wanted to drill steel plate and then box it all in with my heims mounted vertically, but with my equipment, drilling those large bolt holes is a bitch.
    So, I ended up building based off the Shreddder plans with a few modifications. It's not double shear like I wanted, but for this buggy should work.
    After welding the round tube, I squared it off with angle for some flat surfaces to work with.
    I pressed the caliper mount back onto the snout and looks like everything will work.
    I need some jam nuts or spacers for my heims as they need to be 5" center to center, so disregard the miscellaneous washers, etc.
    I am really hating my welder right now...the spool was sticking and then "recoiled" so now when I weld, the wire tends to "pop" on me. Splatter gun looks like crap anyway, but even more now!
    Oh well...it's a woods buggy so it will be covered with mud and probably get bent anyway! It won't be pretty but hopefully it will be finished!
  1. Quad a-arm bushings question
    By Xbird in forum Suspension - Wheels & Tires
    Last Post: 11-04-2014, 10:58 PM
  2. Quad Spindles? Single seater Tiny Mini
    By rgvkid in forum Suspension - Wheels & Tires
    Last Post: 10-13-2014, 11:51 PM
  3. Super rookie question about spindles and stubs
    By h8rstyle in forum Suspension - Wheels & Tires
    Last Post: 03-24-2013, 11:00 PM
  4. Quad spindles durability in a mini rail?
    By minirailguy in forum Suspension - Wheels & Tires
    Last Post: 07-23-2010, 01:59 AM
  5. Quick steering question, ATV spindles
    By andy777bmx in forum Controls and electrical
    Last Post: 10-07-2009, 09:41 PM
