Page 4 of 13 FirstFirst ... 2 3 4 5 6 ... LastLast
Results 31 to 40 of 129
    Re: Shredder 2 build
    #31
    Quote Originally Posted by Texan77 View Post
    All this sprocket and chain info is confusing. Let's say I use a Comet Duster torque converter. The driven pulley has a 1" diameter hole. So I need a 1" shaft to go through that and have my small sprocket on that shaft correct? Let's say I am going to use 12t and 60t sprockets. I cannot find a 12t and a 60t to fit the 1" shaft with the same chain pitch.
    sounds like you have the idea, but the 12 and 60 T sprockets won't share the same shaft. the 12 will be on the driven jackshaft then the 60T on your axle. Plenty of choices of 50-series sprockets (same as #530 chain) with the smallest being 10T iirc.
    As far as the axle goes, that's down to how or what you build your carrier with. Again, like lug nutz noted, you can weld a hub on, or modify something like an atv carrier and have a bolt on hub on a splined shaft.
    #32
    But doesn't that 12t go on the same shaft as the secondary pulley?
    #33
    Yes. your questions made me think you were looking for the same size dia for the 12 and 60. Is finding the same tooth pitch the issue? a #50 size sprocket will run 530 chain and plenty are out there with a 1", 1/4 keyed diameter. A 530 bike sprocket or a custom made one is what you're after for the 60 T
    #35
    Yep, this site is great!
    #36
    Tried the shocks I bought for the front in the rear. Don't think they are gonna be stiff enough.
    #37
    Senior Member Jerm's Avatar
    Dec 2013
    Ontario Canada
    Looking good. I know the plans call for the shocks to be mounted like that. But if you ask Lugs and a few others on here its best that you mount them closer to straight up and down. The reason is because the shocks don't need to work so hard to keep the thing up.
    #38
    That looks sweet!!!! Your progress is going great. Can't wait to see how the progress goes from here.
    #39
    Also mount them as close to the axle as you can get them.
    Speedway motors sells coil springs that will fit those shocks they arent very expensive.
    you will need about 100-125# spring on the front the rear would be somewhere around 150# spring.
    I run 100# springs on my front shocks, had it up to 150 but thats too stiff of a ride.
    You should weigh each corner after its built so you know the how heavy to go.
    #40
    If I did change the spring, what's the best way to remove them and reinstall new ones? Looks like that would be a difficult job.
    Another option is to buy a pair of shocks for the rear that have stronger springs. I'm having a difficult time finding inexpensive shocks though.
  1. Two seater mini buggy build, side by side
    By PeteNado in forum Projects in Progress
    Last Post: 08-29-2014, 03:39 AM
  2. Amer's ST4 build
  3. new 4 seater build project---need ideas on engine n trans to use
    Last Post: 01-08-2013, 08:24 AM
  4. Shredder 2 build
    By ironworkerlocal9 in forum Projects in Progress
    Last Post: 12-22-2010, 05:10 AM
  5. My first build
