Page 2 of 13 FirstFirst 1 2 3 4 12 ... LastLast
Results 11 to 20 of 129
    Re: Shredder 2 build
    Lugs, I see you used a rear wheel with 5 on 4.5 bolt pattern. Everything I'm seeing shows the s10 with a 5 on 4.75 pattern. I'm having trouble finding wheels with that pattern for atvs and the like. Just trying to find everything before purchasing cv axles and hubs. Also what size wheels did you go with?
    Senior Member Jerm's Avatar
    Dec 2013
    Ontario Canada
    I recall reading on here that he used wheel adapters on his buggy, not sure if he used them on the front or the back though.
    Jan 2012
    SLC, UT
    Wheel adapters on the back, the front are 4 on 4 hubs
    I guess my next questions would be:
    If I use s10 axles, are there hubs that will fit them that have a 5 on 4.5 pattern or something more common or am I going to also have to buy adapters?
    On another note, gonna try to mount the seats today. Some parts came in today.
    Jan 2012
    SLC, UT
    you could always get the hubs drilled for the pattern you need. There is enough room on there to make the bolt pattern smaller.
    Installed the shocks I bought on eBay. I only bought two to see how they would work in the front. Not sure if they are stiff enough for the rear. Also purchased s10 axles from advance auto parts like wschilawski. Found hubs on eBay as well.
    Also mounted the seats with a drivers side slider but I removed them before taking a pic so do some more welding.
    Jan 2012
    SLC, UT
    If you need stiffer springs Im pretty sure speedway motors sells the smaller diameter springs that will fit that shock.
    You just need to measure the inner diameter and length.
    Mocked up the steering
    received the axles and rear hubs today. Time to work on the rear end.
  1. Two seater mini buggy build, side by side
    By PeteNado in forum Projects in Progress
    Last Post: 08-29-2014, 04:39 AM
  2. Amer's ST4 build
    Last Post: 04-24-2013, 08:55 PM
  3. new 4 seater build project---need ideas on engine n trans to use
    Last Post: 01-08-2013, 09:24 AM
  4. Shredder 2 build
    By ironworkerlocal9 in forum Projects in Progress
    Last Post: 12-22-2010, 06:10 AM
  5. My first build
    Last Post: 12-12-2010, 02:10 PM
