Page 13 of 13 FirstFirst ... 3 11 12 13
Results 121 to 129 of 129
    Re: Shredder 2 build
    Jan 2016
    The Central Valley
    Ok so I am building the shredder 2 , i am going with a Honda cbr 600 of a motorcycle
    Just wondering if I should use the planes for the back set up , I am worried that if I use the planes and the hardware I will just rip it all up with all the rpms I am going to be putting through it.
    Jan 2012
    SLC, UT
    Check this build he did what you want to do with his jackshaft setup.
    https://www.minibuggy.net/forum/proje...ter-build.html
    Hi Texan77 or any other Shredder builders.
    Do you mind sharing what size and how thick the square tubing is on your Shredder rear trailing arms?
    It appears to be 2"x2".
    I am not building a Shredder but building similar trailing arms and would like to know what tubing size is holding up.
    How much are the Shredders weighing with 13HP Predators?
    Thanks
    Herman
    Jan 2012
    SLC, UT
    Yep they are 2"X 2"
    Hi lug-Nuts
    Do you recall the wall thickness on that 2x2" square tubing for the trailing arms?
    That tubing comes in wall thickness from .095 to .250
    Jan 2012
    SLC, UT
    The plans call for 2" X 1/8" square tube for the trailing arms. You can use whichever thickness you like, or can get.
    Lugs
    Thanks for the info and photo.
    I try to build as light as possible so wanted to know what thickness is working.
    The angle welded to the bottom of the trailing arm should help prevent twisting
    Jan 2012
    SLC, UT
    Oh and the buggy with no motor weighs around 500#'s
    Jan 2012
    SLC, UT
    here's a top down pic of the trailing arm
  1. Two seater mini buggy build, side by side
    By PeteNado in forum Projects in Progress
    Last Post: 08-29-2014, 04:39 AM
  2. Amer's ST4 build
    Last Post: 04-24-2013, 08:55 PM
  3. new 4 seater build project---need ideas on engine n trans to use
    Last Post: 01-08-2013, 09:24 AM
  4. Shredder 2 build
    By ironworkerlocal9 in forum Projects in Progress
    Last Post: 12-22-2010, 06:10 AM
  5. My first build
    Last Post: 12-12-2010, 02:10 PM
