Page 12 of 13 FirstFirst ... 2 10 11 12 13 LastLast
Results 111 to 120 of 129
    Re: Shredder 2 build
    Thank you.
    Do any of you guys have parking brakes and what did you use?
    That buggy is rad! Diggin' the black wheels and chrome lug nuts.
    That's interesting those front springs are too soft. I used to put those Empi ones on the back of baja bugs and they always seemed a bit stiff. Maybe they softened the rate over the years. Good job on the build, looks great.
    Dune 500
    Thank you. I looked for stiffer springs and different shocks. I haven't been able to locate anything I can afford yet. I'm gonna try putting the rears on the front and if they work, I'll just get another set of those. I believe they are some replacement for a Joyner sand viper( whatever that is) that I found on eBay.
    You're welcome.
    Yeah, good shocks are pricey. Might want to add some nice thick rollcage padding to the section by the driver's/passenger's head area. Speaking from experience it's not pleasant when head meets cage.
    Dune 500
    Think I have the shocks figured out. I modified the rear shocks and put them on the front and ordered another set for the rear. On another note, I had broken a ball joint that I had purchased from surplus center so I ordered the ones ubuilditplans.com sells. They came in and one of them had a crack in it. One thing after another.
    There are in line hydraulic p-brakes, but they're not really all that good. I always had bleed down issues. Jamar makes one, if I recall correctly.
    I am painting the buggy with POR15 in black. POR15 is awesome paint but I want to do some parts in red and they never seem to have the red top coat in stock. Anyone know of any other decent paint I can get in red?
    Quote Originally Posted by Texan77 View Post
    Quick question on the four angle in the middle, I think they are 54T. The left is upside down and the right is right side up in the manual. But the destructions are a little confusing about tacking the base together... like dont tack 102,103 etc. Can I tack all of the base together or should I wait until I have the seats first to put on 54T? Thanks
    Im sure you have progressed beyond the seat mounts, but I think the reason behind not tacking some parts is so you dont have to remove them if they arent positioned correctly.
    That is all
  1. Two seater mini buggy build, side by side
    By PeteNado in forum Projects in Progress
    Last Post: 08-29-2014, 03:39 AM
  2. Amer's ST4 build
  3. new 4 seater build project---need ideas on engine n trans to use
    Last Post: 01-08-2013, 08:24 AM
  4. Shredder 2 build
    By ironworkerlocal9 in forum Projects in Progress
    Last Post: 12-22-2010, 05:10 AM
  5. My first build
