Thread: SII with CB750
Page 2 of 34 FirstFirst 1 2 3 4 12 ... LastLast
Results 11 to 20 of 334
    Re: SII with CB750
    Feb 2014
    Green Bay, WI
    little more paint...
    Thanks Lugs! I was going to do Cycle X's big bore kit but I figured for a budget build, I'll put the money elsewhere. Maybe next time...
    Re: SII with CB750
    Feb 2014
    Green Bay, WI
    Blasted the head, breather cover, transmission cover, and oil filter cover. Also picked up some pistons and clutch plates.
    Re: SII with CB750
    I really like that its air cooled!!!
    Nice work on the paint
    Re: SII with CB750
    Feb 2014
    Green Bay, WI
    Thanks! Yeah it will be a unique buggy with the 750. I'm still thinking about throwing a fan on there with a switch as the seats will block most of my airflow.
    Re: SII with CB750
    couldn't hurt, prolly a good ieda.
    Re: SII with CB750
    If theres a spot for oil cooler that be a good idea. There are some kits that bolt on where oil filter spins on that will give you the ports for lines. I picked up a complete setup, cooler lines and adapter for $100.
    Re: SII with CB750
    Feb 2014
    Green Bay, WI
    thanks for the advice - CycleX sells an oil filter/cooler combo for $90 so I'm sure I'll get in touch with them.
    Re: SII with CB750
    Feb 2014
    Green Bay, WI
    oil filter/cooler combo ordered
    Re: SII with CB750
    Motor looks great in black! I considered a kz1000 motor for my buggy because it was free, I turned it down because it was air cooled and a wanted a full firewall to keep noise out and it had a dead cylinder, I did a leak down test and it was blowing a lot of air out of the exhaust so I assumed burnt valve. I should have taken it anyway. These air cooled, long stroke engines make a ton of power.
    Oh and belated, but welcome!!
    Re: SII with CB750
    Feb 2014
    Green Bay, WI
    Forgot to mention that I ordered a stainless fasteners set for the motor, along with a cylinder hone, and STEEL! Let the build begin!
  1. cb750 powered buggy
  2. Turbocharged cb750?
    By Elderstarr in forum Motor - Engine
    Last Post: 04-08-2009, 07:33 PM
  3. Honda CB750 - Good for anything?
    By ElPasoEric in forum Motor - Engine
    Last Post: 01-04-2006, 08:58 AM
