Thread: Sii
Page 3 of 49 FirstFirst 1 2 3 4 5 13 ... LastLast
Results 21 to 30 of 483
    Re: Sii
    #21
    Heres a couple more pics
    Re: Sii
    #22
    I picked up a 2000 lb winch today. I also got the front end figured out as far as caster camber and toe in. Other than that didnt get a whole lot done this weekend, but here are some more pics.
    Re: Sii
    #23
    So the Sii plans have you welding tabs on the hubs to accept a bigger lug pattern. I was not feeling so comfortable with that so I went ahead and purchased wheels from summit racing with the correct lug spacing. Weird how you can find what you need when you look. The front are 4 on 4 and the rear are 5 on 4.5 and the wheels match.
    Re: Sii
    #24
    Looks cool.
    Yes I'm back.. No more procrationating.... I have waited too long to write that!
    Re: Sii
    #25
    I got the shock mounts done, had to stretch em a bit the drawings have smaller shocks on this thing. I have 11" travel up front and the same in the rear. Heres a pic with the cv bolted up.
    Re: Sii
    #26
    the roll cage is on and tacked, also got the sides on so your feet wont flop out. Took all the suspension components apart and prepped them for paint. Im just waiting for my wheels then i can roll this thing around. Should have those next week. Then its time for the engine to go back in and get it all wired up and figure out where to place the rad, and fuel tank. I should have the shifter in next week and get the pedals configured. I did get the winch mounts done thats ready now too. movin along.
    Re: Sii
    #27
    Senior Member turbotike's Avatar
    May 2011
    okotoks alberta
    killer trailing arms man there not bendng any time soon!!
    some are built not bought, most are built not thought.
    Re: Sii
    #28
    Ya those trailing arms shouldn't bend, if they do I think someone is gonna need surgery afterwards. I got my wheels today, put em on and of course I'm 3 inches too wide!!! So rather than shorten a arms and redo.shock mounts I went ahead and shortened my hubs inch and a half each. Then removed inch and a half from each spindle, and voila I'm back to 60 inches overall width. Will prolly have to go with a little shorter front tire for turn radius but should be fine. Was going to put a 26" up front but will prolly do a 24 instead. Will post some pics soon.
    Re: Sii
    #29
    I have a rolling chasis, however my shocks are seriously lacking so I ordered some new ones. Guess if I like a low rider my current set up would work. Gonna try the air shocks with reservoirs I think that should work and give me some adjust ability.
    Re: Sii
    #30
    Some pics of my roller
