Results 31 to 39 of 39
    Re: sorta bullet single seater
    #31
    Oct 2017
    Peace River Alberta Canada
    Was going to reuse the dash I had but either something's not compatible or I have wired it wrong, plug in old dash and it won't turn over, plug in the zx gauge cluster and it fires right up. So I will be making a new dash to accomadate the cluster, after 3 days of farting around just seems easier. Puke bucket and tail light mounted, chain shroud also modified.
    #32
    Oct 2017
    After running the engine a bit I noticed the headers were roasting the seat back, throw a ferocious amount of heat, built a plate to protect the seat then decided to throw a fan in as well, see how that works.
    #33
    Dec 2014
    Detroit, MI
    What's the fan for? Cooling the exhaust?
    #34
    Oct 2017
    Just hoping to move the hot air away as the air box inlets are just above the front of the engine, a flat plate with a couple bends is more within my skill set than to make a couple oval tubes to get air from a cooler spot.
    #35
    Oct 2017
    Went with the fugly fuel tank for now, going to try making one. Also made a linkage to extend the throttle cable, kind of Micky mouse but should work till I can get another. Only thing left is the dash, should be able to finish that tomorrow
    #36
    Oct 2017
    Dash done and installed, buggy is up and running. Took it out for a little run, goes like stink! No pics, failed to upload
    #37
    Dec 2014
    Detroit, MI
    Glad to hear its out and running!
    #38
    Oct 2017
    Thanks! Man glad to have it running with no real issues, got a buzz in the shield I built, will have to add some rubber bushings but apart from that alls well
    #39
    Oct 2017
    Went to go for a little ride but found buggy hydolocked on # 1&2, brought it in shop and replaced Orings on seats, all good again. Sure can tell it’s been outdoors, going to have to paint it soon
  1. CBR F3 VW Single seater.
    By Railguy in forum Projects in Progress
    Last Post: 12-09-2013, 08:47 PM
  2. 165 HP single seater 20 valves
    By ptango in forum Show off your toys in here!
    Last Post: 10-21-2010, 10:35 AM
  3. Sand Bullet Hayabusa 2-Seater build -- need help
    By BuggyManiac in forum Projects in Progress
    Last Post: 09-20-2010, 11:37 PM
  4. single seater rail
    Last Post: 11-09-2008, 09:01 PM
  5. my single seater
    By Inline4play in forum Show off your toys in here!
    Last Post: 10-03-2007, 09:37 PM
