Results 21 to 30 of 39
    Re: sorta bullet single seater
    #21
    Oct 2017
    Peace River Alberta Canada
    Going to have to change the name of my buggy as the fz is being swapped out for a zx. With the homemade header and the pods I can't seem to keep it tuned, that and a couple other little issues like the clutch slave cyl and clutch basket, so out with the old and in with the new ( newer) also can't seem to post pics from my phone.
    #22
    Oct 2017
    image.jpgOk got one
    #23
    Oct 2017
    Well that's weird, couldn't see the other pic but it showed up anyway
    #24
    That'll be crazy fun!
    #25
    Oct 2017
    Should be, hope so, I'll be thrilled if I can have some performance between idle and WOT( ok maybe it was not quite that bad) . Any way progress is happening slowly, big difference installing an engine in an empty frame to what I'm going through now, zx7 engine is quite asymmetrical, deep sump pan on left, front mounts offset about an inch, also had to account for drive sprocket farther left for wider section tire on zx7. Have it mounted finally, engine was in and out like a fiddlers elbow, now comes all the fun rerouting hoses and wiring, willl upsize the rad as the zx7 runs much hotter than the fz ( still had vestigial fining on cylinder). looking forward to first run hope the extra HP won't twist off the axels,
    #26
    Oct 2017
    #27
    Oct 2017
    Now for something completely different, I also have finnishitis, the next project is waiting!! this body will hopefully be going on that frame without too much grief
    #28
    Oct 2017
    Site didn't like the pic of the body, failed the upload 3 times.
    Any way it's a 62 F100 short box unibody
    #29
    Oct 2017
    image.jpgGetting close, rads in, clutch and rear brake lines had to move a bit, it's all the little things, everything is subtly different. Starting to get sick of moving and making tabs. Working on the wiring now and making more mounts and tabs. Fired it up just to check on the wiring, sounds good!
    #30
    Oct 2017
    Still making progress, spent whole day shifting things around and making a few tabs, hard work making things play nice in a limited space, next up is the fuel tank. Not sure yet what I'm going to do here, I have several tanks and none are really working, ones a little small, the other is too big for the space now and the third is just fugly, like a boil on the beauty queens arse. Oh well still more tabs to make so I'll have time to think about it.
  1. CBR F3 VW Single seater.
    By Railguy in forum Projects in Progress
    Last Post: 12-09-2013, 08:47 PM
  2. 165 HP single seater 20 valves
    By ptango in forum Show off your toys in here!
    Last Post: 10-21-2010, 10:35 AM
  3. Sand Bullet Hayabusa 2-Seater build -- need help
    By BuggyManiac in forum Projects in Progress
    Last Post: 09-20-2010, 11:37 PM
  4. single seater rail
    Last Post: 11-09-2008, 09:01 PM
  5. my single seater
    By Inline4play in forum Show off your toys in here!
    Last Post: 10-03-2007, 09:37 PM
