Thread: Mig weld bead.
Results 1 to 6 of 6
    Mig weld bead.
    Tonight I tried hooking up the gas to my welder for the first time. I am having issues with the bead of the weld staying on top of the metal instead of fusing. With the flux core, I had no problem with the metal fusing together. With the gas, the bead wants to stay on top of the metal. What should I do?
    Re: Mig weld bead.
    Blog Entries
    1
    Flux core is usually done with reverse polarity. Try swapping it and see if it gets better.
    Re: Mig weld bead.
    I already did that. Everything is set up the way it should be. I’m just not getting good fusion at all
    Re: Mig weld bead.
    The Wizard of Welding kustomfab2003's Avatar
    De Pere, WI
    I replied to your other post....
    CWI CWS CWE
    Re: Mig weld bead.
    More amperage, turn it up.
    Re: Mig weld bead.
    Sep 2014
    West Palm Beach FL
    Blog Entries
    2
    Flux core penetrates pretty well, but it's usually a pretty dirty weld. With gas you need a clean surface to start with, and you might want to try turning your wire speed down. You want to hear more of a buzz and less of a crackle, and keep the nozzle pretty close to the puddle so the gas can do it's job. Wind is bad too, it can blow the gas away.
  1. Bead leak issues
    By Xbird in forum Suspension - Wheels & Tires
    Last Post: 06-14-2017, 12:59 PM
  2. Check out the bead rolled art,
    Last Post: 10-26-2014, 01:38 PM
  3. Champion bead locks needed
    By MBell in forum Suspension - Wheels & Tires
    Last Post: 07-26-2014, 08:46 PM
  4. Bead roll or not
    By buggito in forum Cooling
    Last Post: 10-06-2009, 07:29 PM
  5. Bead lock rims or kit
    By daaboots in forum Suspension - Wheels & Tires
    Last Post: 01-01-2009, 05:39 AM
