Results 1 to 5 of 5
    What are these bits called?
    Senior Member BorntoBraaap's Avatar
    Jul 2013
    Salt Lake City Ut.
    Its a drill bit, but it has a smaller dia. non fluted part on the tip that guides it through a smaller hole. So you have say an 1/8" hole now and want it to be 1/4", sure you could just slap it up on the press and let a standard 1/4" bit "find" its way through, but this deflects around and the location is lost. The ones Im thinking of have that 1/8" plug/guide so it doesnt wonder off of center.
    What are they called? I need to look into finding some.
    Thanks.
    Re: What are these bits called?
    Look for a piloted drill, a core drill, piloted reamer, or you can use a uni-bit if it is thin material.
    I hit the center with a punch. But for thin stuff the step drill bits work.
    Jun 2014
    Upper Peninsula, MI
    I believe what you are looking for is called a counterbore drill
    Jul 2013
    Salt Lake City Ut.
    Thank you.
  1. What Is This Called!?
    By bigkdog in forum Suspension - Wheels & Tires
    Last Post: 06-09-2013, 03:54 PM
  2. Can Someone tell a rookie what these are called!!
    By zklemm in forum MiniBuggy.net Lounge!
    Last Post: 09-17-2010, 06:05 AM
  3. New bits and dyno results
    By MC@ Performance Fab in forum Motor - Engine
    Last Post: 09-12-2010, 03:24 PM
