First, to get this out of the way: This project is not structural...not only will it not be supporting anything, it will actually be supported BY a steel frame. Also, aesthetics are absolutely not a consideration.
Now, I'm welding 1/8" aluminum panels together. There's going to be between twenty and forty 2"-long beads run. Not a big project in itself, but the physical size is fairly large and the two shops I like to use have both already quoted me over $200 for labor ~ significantly more than the project is worth.
So...I have a 100 amp flux core wire welder and I have some solid core aluminum wire. These are the materials I have on hand: Is there a way I can make them work? Can I just slather some flux paste around where I intend to weld to shield the bead?
I have access to a 90 amp stick machine and could purchase some of the aluminum sticks. Has anyone here used the sticks? How well do they work?
Results 1 to 10 of 10
- Join Date
- Jun 2015
- Location
- Texas Panhandle
- Posts
- 556
02-15-2016 10:39 AM
02-15-2016 11:05 AM
Solid wire won't work without shielding gas. If you have an argon supply you could try and rig up a nozzle to shield the weld, or build a box around the weld area and flood it with argon. Not ideal but it's the only way it will work. This also assumes your feeder will push the wire through the whip without piling up, some welders just won't do it without a push pull or spool gun.
I've used aluminum stick before I got my TIG. It works but doesn't make the nicest welds. The biggest issue I had was the work heating as I welded. If I started hot enough by the time I got to the end it was burning through, and if I was cold enough for the end the beginning wasn't hot enough to weld properly. If you're only doing two inch welds that might not be a problem
The stuff burns FAST. Like 2-3 times as fast as steel. Takes a bit to get used to feeding it that quickly. Also clean, clean and cleaner. Wire brush the metal till it's shiny and if you re-start a stick clean the slag off the end of the rod and the old weld before you get going again. Any contamination makes it harder.
- Join Date
- Jun 2015
- Location
- Texas Panhandle
- Posts
- 556
02-15-2016 12:26 PM
I didn't know if using liberal amounts of flux paste might diffuse the oxygen as it burns off like with aluminum rods...I suppose that's what I was hoping for.
- Join Date
- Mar 2015
- Location
- Yettem California
- Posts
- 208
02-15-2016 04:35 PM
With what you have I would say no, might be able to rig up a cheap spool gun but there a couple hundred plus you need argon. if it's not structural and you don't care what it looks like bolt them together ether overlap or but together with small square pieces bolting them together
- Join Date
- Feb 2007
- Location
- Gilbert, AZ
- Posts
- 799
02-15-2016 05:54 PM
Curious, why the need to weld? What type of joint is it (but, overlap, fillet)?
02-15-2016 07:05 PM
I messed with alumaweld sticks before and for non structural pieces it can turn out nicely with a good bit of practice. They sell at HF for cheep and only require a propane torch to use.
Look up some videos on YouTube but dont believe all the hype, good luck.
- Join Date
- Jun 2015
- Location
- Texas Panhandle
- Posts
- 556
02-15-2016 07:08 PM
I want it one layer on the exposed surface so I can't overlap...if I do bolts/rivets there will be backing. If it's welded, though, it'll make it one continuous sheet. Basically I'm stitching together five or six pieces into roughly a 4x6 sheet. Rivets would require a far more complicated support structure underneath it.
- Join Date
- Jun 2015
- Location
- Texas Panhandle
- Posts
- 556
02-15-2016 07:12 PM
The problem is I have a hard time getting my aluminum up to the 750* working temp. I just tried it. All I have is a propane torch...I may go and grab a map gas torch and see if that works. The alumaweld would work and would actually let me stitch everything together instead of just doing 2~4" beads if I could get the temp high enough.
- Join Date
- Jan 2015
- Location
- Norco, CA
- Posts
- 361
02-16-2016 02:42 PM
Why not just purchase a 4' X 6' sheet?
- Join Date
- Jun 2015
- Location
- Texas Panhandle
- Posts
- 556
02-16-2016 02:52 PM
I'll show you in a couple days
Pratice weld of first notch.
By Glock n Ballz in forum FrameReplies: 25Last Post: 05-03-2010, 11:57 AM -
welding mild steel to chromoly
By 1982shawn in forum FrameReplies: 37Last Post: 03-22-2009, 04:16 PM -
Weldng Aluminum with a MIG welder
By jeeplogic83 in forum Shop TalkReplies: 10Last Post: 07-17-2008, 07:23 PM
