Page 3 of 23 FirstFirst 1 2 3 4 5 13 ... LastLast
Results 21 to 30 of 224
    Re: Welding tips and tricks
    #21
    Impressive! Thanks for posting these Bull. This guy makes me feel like a terrible welder....
    #22
    #23
    #24
    #25
    My miller came with the contact tip flush with the nozzle with it fully pushed in. I find myself pulling it out so the tip is recessed for the thinner material to control spatter as well.
    Watch the nozzle too! I fried one a while back when it loaded up with spatter and shorted out against my work piece. Made a nice green flame though!
    #26
    "When it comes to welding stainless steel, getting it too hot can cause it to lose its stainless properties.
    IF that happens, stainless wont be stainless...it will rust.
    If you are welding sanitary stainless pipe, the swab tests will fail because corrosion or rust inside a pipe will provide a place for microbes to grow.
    If you are welding a valve that goes in a pharmaceutical tank, they may have to dump thousands of dollars worth of little blue pills.
    IF you are fabricating a chemical tank out of 316L and get it too hot, its gonna leak from stress corrosion cracking way before it should.
    Stainless needs to remain stainless. So dont get it too hot.
    But its not just temperature....
    Its TIME at TEMPERATURE.
    The trick is to limit the TIME at high temperatures."
    http://www.youtube.com/watch?feature...&v=saYUUWUNAUo
    #27
    Look at this F!@#in guy!
    Beginning is good,rest is replay.
    TIG Welding Tips - 3 Tips that Matter Most - YouTube
    #28
    #29
    #30
  1. Replies: 110
  2. raptor 660 tips & tricks?
    By kid4life in forum Motor - Engine
    Last Post: 03-11-2013, 04:15 PM
  3. 2001 r6 replacing rings. Tips? Tricks?
    By brooksie2113 in forum Motor - Engine
    Last Post: 08-30-2011, 06:12 AM
  4. welding tips
    By dusty6700 in forum How To Do It
    Last Post: 02-09-2011, 04:05 PM
  5. Go-pro tips or tricks?
    Last Post: 01-09-2011, 07:59 PM
