Results 11 to 20 of 22
    Re: New free bender drawing DWG.
    ok I got it to open in a dwg viewer. So I am not that good with the viewer. I can or cant pull dimensions right off it? Or do I just need to take the file to my plasma cutter to put into their machine? I was hoping to cut it out here at home as a bonified home built project. But the local shop is pretty good, they cut my bubmper parts out of the nested .dwg file I emailed them.
    Bend-Tech Dragon Master
    Nov 2009
    You can do some dims in the viewer.
    I uploaded a dxf version as well, change the dwg to dxf on the link.
    Nov 2009
    ok thank you. ill pull it up when I get home tonight
    Thanks for the information. I decided to just give it to my local metal shop to cut out. they are doing it for $131 material included. Ill update with pics as I get it together. The shop is a couple weeks out on cutting.
    Mar 2012
    Wellington, New Zealand
    Hey Guys, Thanks for the bender drawings, having the plates costed as we speak. Quick question on bending, does anyone know the minimum bend radius that should be used on 38.1 x 2.6 DOM tubing? and do you have drawings/sizes of the bending dies?
    Cheers
    That's a big chunk-o-steel.
    Not to hijack your thread, but I made my own as well using the Chopper Builders' Handbook (basic JD2 model 3). Plans a re free online. Only welding required was the assembly of the DIY kit from SWAG (but you can buy them welded).
    Cost breakdown:
    Plans - FREE (internet)
    Stand - $10 (garage sale pick, weight rack)
    1/2" Steel bar - $60 (eBay @ Detroit)
    Hardware - $25 (Home Depot), all Hi-grade
    Pins - FREE (had 'em)
    A/H cylinder - $96 (HF, incl shipping)
    Chunk of aluminum for shoe (free scrap I had)
    1.25" ID x .50" spacers - $4 (eBay, used for rear shoe and for front catch)
    SWAG mount - $100 (swagoffroad.com, incl shipping)
    Grand Total: ~$295
    The bare bones JD2 model 3 bender will cost you $295 + s/h and no die, no air/hyd cylinder and no cyl mount, but it comes neat & ready-to-assemble. I made my own 1-1/4" die, but the bender accepts the jd2m3 dies.
    Nov 2009
    Quote Originally Posted by DMoneyAllstar View Post
    Cost breakdown:
    Grand Total: ~$295
    That takes 2 pulls for a 90?
    Also I've seen a bunch of bent ram pictures with the swag bracket, the load path is poor at best.
    I definitely prefer this style with vertical bends over the horizontal ones regardless, I don't have a ton of room.
    Ok, I'm a bit embarassed to ask, but is there a way to convert this into a simple template? I have a plasma cutter and I work in a stamping plant. I just need the dimensions of the hole sizes and locations.
    I have Key Creator and PCDmis here on my laptop and both give me nonsensical dimensions.
  1. Free bender
    By Cletis in forum Shop Talk
    Last Post: 02-15-2011, 02:10 PM
  2. New bender for Polaris RZR roll cage.
    By Gundog in forum Frame
    Last Post: 11-11-2010, 04:03 AM
  3. Want To Start Drawing My Buggy - Any CAD For Linux?
    By nitsanbn in forum The Drawing Room
    Last Post: 04-29-2010, 01:45 AM
  4. OHH NO!!!! Another HF Pipe Bender Thread
    By boostick4 in forum Shop Talk
    Last Post: 10-08-2007, 11:06 PM
  5. Site Drawing for Free copy of Bend-Tech EZ
    Last Post: 05-23-2005, 01:06 PM
