Results 1 to 3 of 3
    Tooling material
    Sep 2007
    Saskatchewan, Canada
    I am looking for some 5/8" material to make an internal grooving tool for my lathe. It will be used on mild steel material. I will have to machine it to the configuration that I need then harden it with heat. Will the material in the link below work.
    http://www.ebay.ca/itm/Tool-Steel-Gr...item4ab0f0b315
    Re: Tooling material
    Jan 2007
    Metamora, Michigan
    I would use high speed steel.
    I make them using 1/2" square high speed steel tool bits.
    Grind the shape you need and it's ready to go.
    Run really slow and use use lots of oil.
    Sep 2007
    Cool, Thanks. I never thought of that. I was thinking of doing this because I don't have a very good grinding stone for my bench grinder. I screwed up the last one I tried to grind.
    http://madmodder.net/index.php?topic=3523.0
  1. badland st3 material list???
    By hotrodt in forum Frame
    Last Post: 11-24-2011, 05:31 PM
  2. Here's a great custom tooling supplier
    By Shmeefer in forum Shop Talk
    Last Post: 06-04-2010, 03:57 PM
  3. Material Substitution (size)
    By BrianG701 in forum MiniBuggy.net Lounge!
    Last Post: 02-19-2008, 08:58 AM
  4. spindle and hubs material or source
    By hansshanks in forum Suspension - Wheels & Tires
    Last Post: 10-31-2007, 01:28 AM
  5. MLM hub ring material advice
    By amergin in forum Driveline
    Last Post: 09-26-2007, 12:49 AM
