Page 2 of 7 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 63
    Re: Cnc bender project....
    Bend-Tech Dragon Master
    Nov 2009
    Refresh I had some issues
    The big deal is to have the cutting head air-cylinder out of the way till needed.
    Ahhhh...slick! Cut the tube..cutter slides back...bend the tube...cutter slides back in...cut the tube?
    Nov 2009
    Yey, uses a 157-tooth ford ring gear cheap like $25.
    The little 12 pitch gears were a little hard to find then only 1/2" shaft, need bushings.
    The idea is if one gear hits the open zone you will still hav the other gear making mesh.
    Same with the multiple skate bearings. Farkn brain bender till about 9pm then it all made sense.
    I need this machine to pump out my F150 Struggy.
    Very cool! I didn't even notice the dual drives the first look.
    I like it.
    I think I asked somewhere here if one of those ring gears would bend a tube....but you said no! This is a more realistic use for one! HA!
    Vendor - Rorty Crisco's Avatar
    Aug 2013
    Sunshine Coast, Australia
    Cool idea. Can you add on a bit where it cleans the tube, welds it together and then powder coats it?
    Seriously though - you mentioned in one of the other posts about sanding the tube in the process ready for welding - did you drop that idea?
    Nov 2009
    For MIG we don't bother cleaning much just knock the dross off.
    TIG you may want to prep some, no real better mouse trap yet.
    Aug 2013
    If you think of one make sure I can add it to my 4 axis Tube Pro!
    Laguna Niguel, Commifornia
    Dammit...... My wallet is going to be lighter once this is pushed to production...
    Gotta be something slicker than the jd3 style bender for this? No planetary out of some Toyota transmission that would work?
    Think hydraulic recirculating ball screw rack and pinion....like my power steering box idea....but one that can go all the way around!
    Nov 2009
    I do like the chain drive bender on pirate I saw.
    Don't want to be a die marker tho.
  1. New bender for Polaris RZR roll cage.
    By Gundog in forum Frame
    Last Post: 11-11-2010, 05:03 AM
  2. OHH NO!!!! Another HF Pipe Bender Thread
    By boostick4 in forum Shop Talk
    Last Post: 10-09-2007, 12:06 AM
  3. Project Logs
    Last Post: 05-21-2005, 06:41 AM
