Results 1 to 9 of 9
    Clutch for chains
    Hey people
    I plan to use a chain drive, for single/ double step reductiopn, after my CVT...
    I've figured out everything, except how do i put my vehicle into neutral...
    I mean, if i had a gearbox, i had a clutch, but what do i do now ??
    Any suggestions ?
    Re: Clutch for chains
    Most CVT vehicles stop when you let off the gas.
    Sep 2011
    Chattanooga, TN
    Like Livewire said, the CVT should disengage much like a torque converter on an automatic at low rpm. How it's adjusted or designed will determine how soon it starts to engage as rpms increase. I think it's a good idea to have a good parking brake on any buggy as a precaution. It's probably also advisable to never let the engine run when you leave the driver's seat.
    SO, the whole story returns to tuning ?
    Alrighty...I'm pretty good at it
    But again, any idea about performances of chains ?
    I mean,i personally love chains, but haven't tried at baja...you guys ever did ?
    Oct 2011
    West Michigan
    Really depends on designing it right. What chain size? What RPM? How heavy is your ride? What reduction between the sprockets. Since you are only running 12 hp you can't go too far wrong.
    Right...
    Also, is there any god damn way you can incorporate reverse into chain drives ?
    I mean, any standards exist or it gotta be customised ?
    How much power?
    The engine is about 8kw...but obviously, it doesn't go that high, because the low rpm's involved....
    An old snowmobile reverse box or Polaris ATV reverse box would work.
  1. Arctic Cat 660 Turbo drive clutch seizure problem
    Last Post: 02-02-2014, 02:16 PM
  2. clutch question
    By RedDesertCat in forum Driveline
    Last Post: 03-02-2012, 08:17 PM
  3. Cvt clutch brace
    Last Post: 11-28-2011, 12:53 AM
  4. driven clutch swap question
    By Scottbrock in forum Honda's Pilot & Odyssey
    Last Post: 10-31-2011, 12:50 PM
  5. How to widen/space Driven clutch?
    By bighead in forum Driveline
    Last Post: 02-19-2011, 12:49 AM
