Thread: Mini 1275 to FJ 1200
Results 21 to 30 of 64
- Join Date
- Dec 2012
- Location
- Pretoria, South Africa
- Posts
- 51
02-16-2013 11:20 AM
- Join Date
- Dec 2012
- Location
- Posts
- 51
02-16-2013 11:44 AM
I connected the axles today and temporarily the wires and took it for a spin, the power is incredible
and it is very responsive but, for some reason the rev counter isn't working,does anyone have any ideas?
Thanks
- Join Date
- Dec 2012
- Location
- Posts
- 51
02-22-2013 01:19 AM
So nobody knows about the tach, it also seems that the battery isnt charging?
- Join Date
- Dec 2012
- Location
- Posts
- 51
04-07-2013 12:18 PM
I sorted out the issues with the battery, but after riding on the farm the 2 middle cylinders lost their spark, I cleaned all the connections but still, no luck.
04-07-2013 08:13 PM
If you lost the middle 2 cly....you probably lost a coil, fj1200 1 and 4 share a coil 2 and 3 share a coil....first check and make sure you have a good ground to the body of the coil (you can run a wire from the mounting post directly to a good engine ground). next I would swap the wiring on the 2 coils, after you do that you should lose cly 1 and 4...if so bad coil, most of the time it is due to grounding.... but have had the coils go bad too.
BTW....the grounding problem can also affect your tach...
- Join Date
- Dec 2012
- Location
- Posts
- 51
04-08-2013 05:56 AM
Thanks, I will try that as soon as I have time.
- Join Date
- Dec 2012
- Location
- Posts
- 51
06-18-2013 07:10 AM
I finaly got the time, or the courage to test the other coil, both work but the middle one wont fire when connected. After a short while of testing both the coil that doesn't fire as well as the ic-ignitor get a bit warm.
Thanks, Erik.Last edited by FJ1200Buggy; 08-09-2013 at 10:30 AM.
Mini Lite's: Race Car
By TutTech in forum Tut-Tech GroupReplies: 303Last Post: 03-28-2014, 05:39 PM -
Mini A Arm Buggy for Kids
By TutTech in forum Projects in ProgressReplies: 163Last Post: 03-03-2011, 12:06 PM -
2 Seat Mini 4X4 Buggy
By TutTech in forum Projects in ProgressReplies: 29Last Post: 12-17-2009, 12:05 PM
