Page 42 of 42 FirstFirst ... 32 40 41 42
Results 411 to 418 of 418
    Re: The Next Rorty R82s build
    Senior Member Kludge's Avatar
    West of Portland, Oregon
    Quote Originally Posted by dune\";p=\"34136
    I have a 12t sprocket and some bearings. I need the sprocket bored to accept the bearings. If anyone is up for the task, it would be great. I'll send the sprocket bearings and $$.
    Hi Dune,
    I can help you with the sprocket bore, send me a PM.
    I also think I have a #50 roller bearing idler kicking around in the shop that I could sell.
    /Frank
    Senior Member dune's Avatar
    Sep 2006
    Vancouver, Wa
    Thanks for the help guys. Tim I went ahead and ordered a couple from McMasters.
    Thanks,
    Tripp
    Re: More Progress
    Quote Originally Posted by dune\";p=\"13964
    Well, I was able to get some more progress done on the car. The bottom frame is complete minus the front end (pivot/rack plates, waiting on them to be cut) and the motor mount. So I removed the BF from the table and laid out and framed the Upper section. The R82S is basically composed of 4 sections or layers. The Bottom, Lower(all webbing),Upper(mid level frame) and Top section. Next I'll replace the bottom frame on the table and position the upper frame over top and suspend with temp arms while I cut and install the webbing.
    Hi Dune,I have the same steering rack as you have used.
    Can you tell me what fittings and how many did you need i.e u-joint,connection to steering rack and 5/8-36 splined shaft ends did you end up using this would be a great help as my wife Christina is heading over to Boston again next month and I can have the parts sent to her cousins. The parts are about a third of the price from USA than here in the UK.Regards Sam
    Sam,
    He may not be watching the board so send a PM. I could call him if you like and get pics. He's about three miles away from my house.
    Quote Originally Posted by Gene\";p=\"43969
    Sam,
    That would be great if you could give him a call Gene Regards Sam
    how much does your buggy weigh all together?
    Send Dune a PM. He's not here much. I've seen and ridden in his car and my guess is that it weighs 1100 to 1200 range.
    Great job. Im thing about building a R82 myself and your post has really helped me out with ideas.
