Hi Guys, I need some direction. I have a Bob Rorty R6 with Fox Emulsion Coil-Over Shocks.
Front shock I am currently using;
Front spring
- Top-1200.250.0150
Bottom-1200.250.0150
Rear spring
Top-1200.250.0125
Bottom-1200.250.0200
Front buggy weight-330pds
Rear buggy weight-662 pds.
Am I even close to a good spring set up.
Thank u eric
Thread: Springs
Results 1 to 2 of 2
- Join Date
- Jan 2007
- Location
- riverside,ca
- Posts
- 98
04-04-2015 07:16 PM
04-06-2015 05:15 PM
I'd work with the guys from downsouth motorsports. In addition to the info above, they will need to know motion ratios and unsprung weights for each corner.
Although if this is a stock setup for the Rorty car, other members may be able to tell you exactly what they are running.
Choosing the right Springs.
By Daniel_M in forum ST4Replies: 4Last Post: 12-03-2014, 08:01 AM -
Springs and Weight help
By codydewar in forum Suspension - Wheels & TiresReplies: 5Last Post: 09-17-2013, 03:04 AM -
Wanted to buy ... coil over springs ...
By Xbird in forum For SaleReplies: 0Last Post: 08-01-2013, 06:28 PM -
Springs
By TEO in forum Suspension - Wheels & TiresReplies: 0Last Post: 03-29-2010, 10:06 AM -
spring rate
By enroffroad in forum Suspension - Wheels & TiresReplies: 3Last Post: 11-29-2007, 03:40 PM
