Page 11 of 13 FirstFirst ... 9 10 11 12 13 LastLast
Results 101 to 110 of 130
    Re: My first buid: Rorty shotgun
    Thats what i think im going to do. Make some washers.
    Feb 2006
    Winder Georgia
    dont really see what it would matter....If not ask kfab, he has means to make them, just not sure about time...
    Go
    Todos Santos Baja Mexico
    we had / have the same problem. we have found some hardened steel washers that make it fit perfectly. On ours we used 2 washers one on either side of hi-mis. We noticed this a while ago and when we jigged up the up rights we cut some spacers to allow for the 2 washer setup. hope you got the idea. on a couple of them we had to sand down a washer a little though.
    ________
    MARIJUANA STRAIN INDEX
    Look at ChassisShop.com for safety washers in the Aurora Rod ends catalog. Between ChassisShop and Oregon Motor Sports I found two types washer in different thickness. These were used in my car's rear suspension uprights and it's all good.
    Okay I think i have a solution. If I put some high grade washers on each end of the spacers and cut down the hi mis spacer on the lathe just enough for it all to fit.
    It would be much easier this way then trying to cut some washers or sand some down.
    What do you all think? Good idea?
    Short of getting the right ones, that sounds better than sanding some washers (so they're non-parallel and thus straining the bolt unnecessarily). Good solution! *
    Okay thats what Ill do then!!! *That ones solved
    Thanks
    Blog Entries
    1
    Tack weld the washers in, it will make assymbly much easier.
    Hey all, buisness been slow so I had to put the shotgun on hold. I officially took it off hold status today.
    Leaving for Dunefest on saterday. Me and the Alba action sports guys are gonna take the scenic route to Oregon from San Diego. I love road trips!!!!
    Anyway will be back at building as soon as I get back.
    Anyone else going to Dunefest? Let me know and we'll meet up and have a beer.
    Hey San diego - several of us will be at dunefest Saturday in lot 3. We are staying at Best Budget Inn, Reedsport. We plan to be at Florence Sunday morning. I'll PM a phone number.
