Results 1 to 3 of 3
    R82 or Shotgun engine
    Aug 2014
    moses lake WA
    I'm considering either the R82 or the Shotgun plans for a mini buggy build. I was looking to see if anyone is running a Honda or ecotec in either of these chassis with a cvt setup. If so did you have to lengthen the back section for a bit more room. Most of my time will be spent in desert environment so I'm leaning toward the shotgun.
    This will be my first mini buggy build and I'm sure I will have many questions along the way
    Re: R82 or Shotgun engine
    Senior Member spud nut's Avatar
    Jul 2011
    Nampa, Idaho
    I am doing a shotgun as well and I have a CVT for sale for an Ecotech. I just bought a complete motor set up from Alpha Fab Industries today and I have chosen to use a built type 1 trans axle instead of the CVT. I too will be 90% desert and wanted to shift for hills up and down.
    Good luck on your build and I will be watching for updates.
    Sep 2008
    Allendale MI
    Check this build out. Shotty/ecotec build.
    https://www.minibuggy.net/forum/proje...gun-build.html
    Im pretty sure the cage is dimensionally to the prints.
    Justin
    Nowhere near the desert.
  2. Adding a oil cooler to Arctic Cat 660 turbo engine
    Last Post: 09-14-2013, 07:13 PM
  3. Honda Pilot FL500T Evil Twin build
    By asaszn in forum Honda's Pilot & Odyssey
    Last Post: 04-12-2012, 11:43 AM
  4. Tom's Buggy Build
    Last Post: 08-06-2011, 03:40 PM
  5. Why is Oil So Critical to My Engine?
    By installers in forum Cooling
    Last Post: 03-06-2011, 10:04 AM
