Results 1 to 5 of 5
    Sprocket gear Coupling from output shaft of the transmission to gearbox Ridge Runner
    Hi -
    I have a 2007 RR the gear or sprocket between the transmission and the gearbox went bad the spines stripped our. Anyone have an idea where I can get one. This is not a Polaris part it looks custom for RR any thoughts.
    Sprocket gear Coupling from output shaft of the transmission to gearbox Ridge Runner-sprocket.jpg
    Re: Sprocket gear Coupling from output shaft of the transmission to gearbox Ridge Run
    That’s an odd looking piece. It actually makes me think of an item called a Taper-lock. My supercharger has them on the pulleys. They have a tapered collar that is drawn into the outer housing, clamping the collar down on the shaft as it’s pulled in.
    Here, this is the unit (this site is not in the US but gives you an idea how it works). Search a bit more and you may find what you’re after: https://www.c-rproducts.com/products...lock-bushings/
    Ooohhhhh! McMaster has them:
    Inner piece: https://www.mcmaster.com/taper-lock-bushings/
    Sprocket half: https://www.mcmaster.com/taper-lock-sprockets/
    Duck in a Tux jimmyg's Avatar
    Sep 2016
    Bendigo AUS
    Why would you go anywhere else for help.
    Yes it is odd for sure. There is a part number on it is Martin 5016 but the original stock Martin 5016 part has a key way where my RR pat is has a spline in the middle of the sprocket/gear. Any thoughts?
    Sep 2016
    Bendigo AUS
    How are the spline's on the output shaft? Can you take a pic of the output? If they are ok then an engineering shop can reverse build the center spline section. Last resorts deal but an option if the output shaft is good.
  1. Flex coupling in sprocket/chain drive set up
    By Crisco in forum Driveline
    Last Post: 03-25-2015, 09:42 AM
  2. Ridge Runner
    By gillok02 in forum Ridge Runner
    Last Post: 07-17-2011, 03:15 PM
  3. Welcome To Ridge Runner
    By Gene in forum Ridge Runner
    Last Post: 03-24-2007, 09:34 AM
  4. transmission output shaft question
    By FLATLINE_curious in forum Driveline
    Last Post: 04-27-2006, 07:16 PM
