Results 1 to 7 of 7
    Front Wheel kits - How to - front brake lines
    S.W. Michigan
    There are different ways of doing the front brake lines but thought I would share a closer look on what we do with our front wheel kits and A arm set up.
    It can be confusing finding the right fittings and parts the 1st time
    On the Wilwood caliper, we plug the original inlet hole with 1/8 NPT plug.
    1/8 npt Brass Plug
    Then remove the top bleeder and replace it with a -3 to 1/8 NPT fitting.
    Brake Line Adapter Fittings
    Then we use a 24" 90 deg braided flex line going to a -3 to 3/16 inv flare fitting and a tab welded to the chassis or you can drill a hole in a body panel and clip it
    Brake Line Flex- 90 degree 24"
    Brake Line Adapter
    Brake line adapter Mounting Tabs
    Brake Line adapter Clips
    from there we hard line it to the 3/4 Master cylinder
    Inverted Flare Nuts
    Brake Line Coil 3/16
    to either of these
    Brake Line Adapter Fittings - 90 degree
    Kfab, would it be possible to add a how to / help section under the Protodie build section?
    Just thinking it would be a good place for some of the misc questions specifically referencing our plans and buggy builds
    Re: Front Wheel kits - front brake lines
    Oct 2011
    Bozeman, Montana
    Great Post! Thank you!
    Timing was perfect, I'm at this exact stage in my build
    S.W. Michigan
    glad it helped your build
    Shouldnt the bleeder be on the top? Unless pressure bleeding I guess.
    I learned that the hard way in 10th grade when putting disc brakes on my 67 camaro!
    S.W. Michigan
    good point Bull.
    there are bleeders on top and bottom, with the exception of the one I removed.
    This is now the inlet where the oil is coming from though so should not be able to trap air there.
    I should add that when I bleed them I do not even have them mounted on the front upright.
    I take a small piece of 3/8 thick steel, put it between the pads and run some electrical tape around it to keep it in place.
    This makes it easier for me to have the caliper over a catch can and not get brake fluid on other parts while bleeding the brakes
    Senior Member Beruba's Avatar
    Feb 2014
    Alberta Canada
    The front brakes hook up to the 3/4 master cylinder.
    What hooks up to the 7/8 master cylinder?
    S.W. Michigan
    I run 7/8 on the clutch.
    so two 3/4 master cylinders for the brakes and 7/8 for the clutch
  1. Micro Stub Fundamentals
    Last Post: 04-06-2015, 11:28 AM
  2. Protodie Front Wheel Kits - 4 Bolt
    By JD66 in forum For Sale
    Last Post: 05-05-2014, 07:37 PM
  3. Desert Dog Coyote - Test drive report.
    By K-fab in forum Desert Dog's Coyote
    Last Post: 08-28-2007, 03:13 PM
  4. Front brake set up dilema
    By buggito in forum Suspension - Wheels & Tires
    Last Post: 05-08-2006, 07:52 PM
  5. Front Wheel Alignment For Off Road Kart
    By BigD in forum Suspension - Wheels & Tires
    Last Post: 03-22-2006, 09:21 PM
