Thread: body panels
Results 1 to 10 of 15
    body panels
    Not a project in progress but k-fabs posts about carbon fiber and such got me to thinking. When I did the body panels for my 180 bph dragster I wanted panels that were strong and flexible and kevlar fiber was out of my budget back then.So what I did was to laminate 10 layers of 4 oz.fiberglass cloth. This made panels that are .100" thick. The process is very easy. 4oz.cloth is extremely pliable *and so is easy to follow contours.There are several places to buy the needed tools to do so correctly.The tools needed are an assortment of "bondo" plastic squeegees-2,4,6" wide.A 1" and 3" grooved 3/4" diameter roller for spreading the mixed resin and thoroughly saturating the cloth. A SHARP pair of NEW scissors.A snap off blade razor knife.mold release wax. FOr very flexible parts and very strong panels step #1-apply liberally a coat of mold wax to your plug form.Allow to dry.If you can get it spray 2 coats of PVA(polyvinyl alcohol) on the mold release wax.#2 brush a coat of resin on the form.#3 lay a dry layer of cloth to the resin.#4 pour a small quantity of resin on the dry cloth and spread into the cloth being sure to totally saturate the cloth. do the entire area . #6 Squegee all the resin you can from the cloth. #6 repeat for 9 more layers.#7 when the completed part begins to firm up it can be trimmed to near final size with the razor knife.Use a 2 hour set time formula when beginning so as not to be rushed and if you want minimal distortion in a large part like a hood or something.Use the scissors to cut the dry cloth.Clean up with tools and such with acetone. this will give a part that will take extremely hard impacts since it is rigid yet able to bend in about a 10" radius. Much cheaper than carbon fiber and yet very strong. I ran into the back of another dragster in the staging lanes and didn't even crack the nose.
    Re: body panels
    Quote Originally Posted by masterfabr\";p=\"38108
    There's an echo in here-ere-re-
    Re: body panels
    Huh?
    Re: body panels
    Quote Originally Posted by masterfabr\";p=\"38114
    Huh?
    You posted two identical threads. Probably best to delete one of them.
    Re: body panels
    Wow, I only show 1.?????
    Re: body panels
    Maybe the server had a brain fart or a mod deleted the other one.
    Re: body panels
    Probably why I can't download those .dxf files!
    Re: body panels
    I saw that it was a double post and removed the other one already. *Nobody had replied to either thread yet, one had been read four times, the other three. *I believe I removed the one that had been read 4 times.
    Re: body panels
    Sep 2005
    Pacific Northwest
    Good info. *I agree. *I have done similar lay ups with great results. *The glassing is pretty easy, the tedious part is getting the plug made nice and all smooth etc ... the part of the process that Kfab is doing now.
    Re: body panels
    making a smooth plug is actually easy if you will use Duratec primer over the foam after sanding it to shape.Use Duratec in place of the foiltep in k-fabs thread..Duratec is sort of like a gel coat but is relatively easy to sand and polish for a great finish on the finished part pulled from the mold.If you haven't used it before you will be very happy with it if you will do so.
