Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
    Couple little buggies I have been putting together
    Sep 2006
    New Mexico
    Me and my brother wanted some small buggies that would fit in the back of our pickups to go tear it up with our quad friends on their trails. *They are very light and were very inexpensive to build. *Nothing real elaborate like the other rails here. *Just something simple to get the job done and have some cheap fun. *Each of them cost a little under $2k to complete. *They weigh in at approximately 460 lbs. with no driver. *Both are 600cc MC powered with about 100hp each. *Still have a few little loose ends to tie up but I am about a weekend away. Yes, one of them is a chain guard...
    Re: Couple little buggies I have been putting together
    Looks what is the overall width?
    Looks like a lot of fun for the cost. *You must have gotten a pretty good deal on the motors though? *Are the axles out of something, or are they custom made? *What kind of rear hubs are you using.
    Are the front shocks on the red buggy off a 400ex?
    They both look great
    thats a great price for what you have. *looks real good. *great job.
    Sep 2006
    New Mexico
    60" width on the rear, 54" on the front. *I made the u-joint axles myself with spicer components from my local driveshaft shop. *Yes, the red one has 400ex shocks on the front. *These buggies are as light or lighter on the front end of the quad because of where the weight is positioned so I think they should work well. *I made the rear hubs myself. *2" ID tube, 1" ID sealed bearings, 1" keyed shaft threaded on the end for a retaining nut with a cotter pin through the shaft, [url=http://www.bmikarts.com/shop/?shop=1&cart=474787&cat=1&itemid=1093&&thumbval=th umb&showFullImage=:1kjzo3ql]with these hubs from BMI[/url:1kjzo3ql] and thats about it. *the other side of the keyed shaft has the yoke directly on it. *I used this setup on my last 600cc 2 seater that weighed about 800lbs or so and it worked well so it will be fine for these lighter buggies. *They should be smokin fast with this kind of power to weight ratio. *Probably hardly ever come out of second gear though!
    Feb 2006
    Winder Georgia
    Standfast excellent work, but please get something between the chain and gas tank, even for a short test ride, i cant imagine if that chain hit...
    But excellent job...have fun...
    Cool rides. *
    I would imagine with the power to weight ratio you have they should scream.
    Your quad buddies are not going to be happy. *
    Whats the top speed with those little rear sprockets?
    Looks like fun,Hope the kwad riders like eatin roost.
    I'm certainly no expert, but i'm supprised no one has commented on the lack of triangulation.Might collapse in a hard rollover. Look like some bad rides otherwise.Especially the orange one
