Actually started this project back in Feb 2021 and it is about done now in June 2022.
I've gotten a lot of good info off this board during the build, so thought I'd detail my build with some info and photos.
Donor engine came from a wrecked 2013 Kawasaki Ninja 650. Bike as purchased.
Pulled the engine out and mounted on a makeshift stand. Plopped the gas tank on top
and flipped the stock exhaust 180deg so I could work on the wiring and get the engine
running on the stand.
Got rid of a good bit of the extra bike wiring I didn't need. Jumped the kickstand and
clutch safety switches. Stripped off the emissions gear & added inline jumped resistors
to emulate the purge and air switching valves.
Added an open-element Spectre filter up top on a modified baseplate & mounted the
intake air temp sensor there. Wiring cleaned up where I could before going in chassis.
Results 1 to 10 of 29
- Join Date
- Apr 2021
- Location
- Gilbert, AZ
- Posts
- 25
06-29-2022 11:17 PM
- Join Date
- Apr 2021
- Location
- Gilbert, AZ
- Posts
- 25
06-29-2022 11:25 PM
Started with KJ Raycing plans and built the chassis jig from 1.5" box tube.
Here is the basic chassis all tacked up in the jig. This is mostly 1.5" x 0.095" DOM.
Basic chassis out of the jig.
Needed to make some 1.25" bends but didn't have that size die. Made short straight &
curved pieces from 1.5" x 0.120" wall tubing. Sliced them in half and used those pieces in
my 1.5" die to make the few 1.25" bends I needed. Worked pretty well.
- Join Date
- Apr 2021
- Location
- Gilbert, AZ
- Posts
- 25
06-29-2022 11:40 PM
Decided to try building my own pedal box similar to those on the market.
Lots of time figuring stuff out & making it, but was a fun project.
Here is the fab in process. Using Wilwood 5/8" masters for brakes. Bought
their balance bar assembly and used it in my fabbed pedal. Small foot plates
are Wilwood pieces. Gas pedal piece is homebrew.
Trying out a Venhill cable for the clutch actuation. Tried to make throttle
and clutch linkages with some leverage adjustment.
06-30-2022 01:48 AM
Mate!!!!
Out of no where roktoy hits the ground running!
Keep it coming bud. Lovin it!All dressed up and waiting for the beer to arrive.
- Join Date
- May 2015
- Location
- Northern California
- Posts
- 297
06-30-2022 03:52 AM
Very nice work!
Dune 500
YXZ1000R
Desert kart "Panther" build
- Join Date
- Apr 2021
- Location
- Gilbert, AZ
- Posts
- 25
07-01-2022 01:44 AM
Front ends uses a 14" steering rack as KJ Raycing recommends.
I made extensions to match the tie rod pivot to the a-arm pivot point.
Steering shaft uses two u-joints to get to the dash above.
Spindles & wheel hubs, discs, etc. are from a Yamaha Raptor 660. A-Arms are
Raptor pieces, 2 inches wider per side from Alba Racing. Trimmed the disc backing
plates to bolt up Raptor 700 2-piston calipers (not installed here).
Shocks are used Fox coilovers from a Polaris quad.
- Join Date
- Apr 2021
- Location
- Gilbert, AZ
- Posts
- 25
07-01-2022 01:58 AM
After a lot of reading & thought, I decided to go with the Dodge Intrepid wheel hubs
and homebrew uprights on the rear. I'd seen a lot builds with these from people on here.
I wanted to use 4 on 156 quad wheels, so turned out adapters for the conversion.
Upright for the Intrepid hub.
All mounted together. Pivots are 1/2" bolts and Delrin bushings in 1.25" tube.
07-01-2022 10:52 AM
Holly crap! You built all that from scratch?
- Join Date
- Apr 2021
- Location
- Gilbert, AZ
- Posts
- 25
- Join Date
- Apr 2021
- Location
- Gilbert, AZ
- Posts
- 25
07-03-2022 07:21 PM
A had a hard time coming up with a center section I liked, but finally settled on
something after I saw a post Brian Eddy (thanks again Brian) posted here:
https://m.facebook.com/groups/414201...n__=%2CO%2CP-R
These are the major pieces. Using one front Ninja rotor on a machined aluminum adapter ring.
Ninja rear caliper. Vortex 452A series sprocket with center machined to fit/bolt on VW flange.
Final assembly bolts are different.
Fabbed center section that pivots and has caliper mount.
Starting here to mount in chassis. Standard 930 CV for mockup.
Another view of the center section being set up in chassis.
Yerf ninja build
By McDog in forum Projects in ProgressReplies: 255Last Post: 04-06-2019, 05:40 PM -
Finnish crosskart
By hybridracers in forum FrameReplies: 28Last Post: 01-16-2016, 01:20 AM -
900 ninja buggy build
By buggymane in forum Projects in ProgressReplies: 49Last Post: 03-18-2013, 11:20 AM -
just got a 600 ninja want to build a rail out of it
By peterpan in forum MiniBuggy.net Lounge!Replies: 7Last Post: 05-02-2010, 11:42 AM -
Ninja powered buggy build
By mdune_100 in forum Projects in ProgressReplies: 2Last Post: 04-07-2010, 08:50 AM
