First time setting the engine in the frame on bottom motor mounts.
Wish I would have extended this portion of the chassis maybe two inches
over the KJ Raycing plans to give me a little more room fitting this engine
in without stealing any more cockpit space.
Designed setup to fit up to a 60 tooth sprocket (shown here).
Started thinking about 2-into-1 exhaust routing and fitting more chassis support tubes.
Results 11 to 20 of 29
- Join Date
- Apr 2021
- Location
- Gilbert, AZ
- Posts
- 25
07-03-2022 07:33 PM
07-03-2022 08:00 PM
It's always the same. Space is always tight and you finish the build thinking if I did it all again I'd do that differently.
07-05-2022 09:48 PM
I came across KJ Raycing's Youtube channel a few months ago and I was impressed with the amount of thought that he put into his builds. I'm glad to see someone building a buggy using his ideas.
- Join Date
- May 2019
- Location
- California
- Posts
- 171
07-11-2022 01:44 AM
I've been watching the KJ raycing YouTube channel since his first build. You have made some serious progress in not that much time and it looks great. I've thought about using his plans for a single seat build in the future, but would probably modify them a little for more cockpit room and more engine room/set up space.
Good luck to you!
- Join Date
- Apr 2021
- Location
- Gilbert, AZ
- Posts
- 25
07-17-2022 04:58 PM
Absolutely!
Fair number of people doing some of his builds (posts on the FB group). Working on I think his fourth one (two-seater).
Actually have been working on this kart for over a year. Pretty much finished....just recapping the build. Thanks!
- Join Date
- Apr 2021
- Location
- Gilbert, AZ
- Posts
- 25
07-17-2022 05:04 PM
Here I was starting to mock up & build the rear a-arms.
Used 5/8" shank x 1/2" hole FK rod ends. 1.25" lower and 1" upper tubes (.093" wall).
Sheet steel dash using the original Ninja 650 cluster & bike ignition switch.
- Join Date
- Apr 2021
- Location
- Gilbert, AZ
- Posts
- 25
07-17-2022 05:10 PM
Bought a 4-gallon fuel cell from Summit Racing & fabbed some mount straps for it.
Used the original Ninja FI pump out of the bike tank. Modified the sender rod to work in the fuel cell.
Machined an aluminum plate to mount the pump in the cell. Just learning to TIG aluminum....
- Join Date
- Apr 2021
- Location
- Gilbert, AZ
- Posts
- 25
07-19-2022 03:27 AM
Working on the rear suspension. Mocking up axle shafts.
Sway bar from a Kawasaki Brute Force 750.
Radiator mount in progress.
07-20-2022 11:40 PM
That moment you see the size of the tires your going to run.
- Join Date
- Apr 2021
- Location
- Gilbert, AZ
- Posts
- 25
08-02-2022 01:38 AM
At this point I decided I should be done with everything on the chassis.
I could either (1) assemble, test, disassemble, paint, reassemble, or (2) paint
the chassis at this point and deal with any changes & paint touch-up as needed.
I decided to go for it.... coating the rest of the chassis with etching primer.
I followed up with Rustoleum hammered shot from a gun.
Finished dash area....
Yerf ninja build
By McDog in forum Projects in ProgressReplies: 255Last Post: 04-06-2019, 05:40 PM -
Finnish crosskart
By hybridracers in forum FrameReplies: 28Last Post: 01-16-2016, 01:20 AM -
900 ninja buggy build
By buggymane in forum Projects in ProgressReplies: 49Last Post: 03-18-2013, 11:20 AM -
just got a 600 ninja want to build a rail out of it
By peterpan in forum MiniBuggy.net Lounge!Replies: 7Last Post: 05-02-2010, 11:42 AM -
Ninja powered buggy build
By mdune_100 in forum Projects in ProgressReplies: 2Last Post: 04-07-2010, 08:50 AM
