Results 11 to 20 of 30
    Re: Yamabuggy 400 swap to 900
    Duck in a Tux jimmyg's Avatar
    Sep 2016
    Bendigo AUS
    Very nice! No extra room anywhere but it fits. Great stuff.
    Ps glad to see the safety equipment. Very wise.
    Some people walk around there workshop in thongs.
    The Wizard of Welding kustomfab2003's Avatar
    De Pere, WI
    Please keep the updates coming... what are your plans for routing the exhaust and keeping the heat down in that tight of a space?
    CWI CWS CWE
    De Pere, WI
    I sure hope you mean flip flops (a man in a thong in the garage is just a bad visual )
    CWI CWS CWE
    Sep 2016
    Bendigo AUS
    I mean flip flops but I come from the land down under.
    Why do I get the feeling this is directed at me (with incorrect wording).
    Quote Originally Posted by kustomfab2003 View Post
    EXACTLY!
    Well… unless it’s cheetah or leopard print.
    I had to correct TALON on this more than once.
    Then again, he couldn’t get the person behind the counter to sell him a bag of ice due to mispronunciation…
    Sep 2016
    Bendigo AUS
    I will add paranoid to the list.
    Don't worry i will update this post to the end
    Exhaust will be custom in stainless steel. Maybe wrap with exhaust insulation, i don't know yet.
    After take in and take out the engine lot of times, i made removable mounts (exept bottom mount) to take out engine later if i need it.
    Using grinder to make tube notcher. It match very well
    Last check before fixing the motor in final position
    Left mount : top part like this to stop lateral movement
    Laser from my house renovation to align mount
    Engine mount above gearbox axle then clutch carter
    The welds are obviously not final, a pro welder will come and do this with TIG
    Sep 2016
    Bendigo AUS
    Great progress. Working very hard.
    May 2015
    Northern California
    Quote Originally Posted by Julien51 View Post
    Yes, I live in the middle of Champagne vineyard, lot of off road way between plots, forest and fields
    Sweet.
    Dune 500
    YXZ1000R
    Desert kart "Panther" build
    Oct 2009
    A good looking shoe horn fit job LOL I can relate to stuffing 100lbs into a 50lb sack as I did the same with mine
  1. Need engine swap help!
    By Dirt400 in forum Projects in Progress
    Last Post: 10-08-2013, 09:02 PM
  2. yamabuggy 250
    By Piersonslawnservice in forum MiniBuggy.net Lounge!
    Last Post: 10-27-2009, 09:46 PM
  3. yamabuggy and engine swap
    By eyco in forum MiniBuggy.net Lounge!
    Last Post: 06-29-2009, 09:36 PM
  4. Yamabuggy 400cc
    By rvtec88 in forum MiniBuggy.net Lounge!
    Last Post: 02-15-2009, 04:09 PM
  5. XATV Yamabuggy
    By Twisted_Sid in forum Turnkey buggies and sand rails
    Last Post: 07-12-2008, 12:16 PM
