Thread: Panther rebuild
Page 29 of 30 FirstFirst ... 19 27 28 29 30 LastLast
Results 281 to 290 of 296
    Re: Panther rebuild
    Duck in a Tux jimmyg's Avatar
    Sep 2016
    Bendigo AUS
    Not sure what type of trees they might be. Same as you most are good smelling that I know.
    Paints come up mint.
    Re: Panther rebuild
    May 2015
    Northern California
    They were very majestic.
    Re-assembly begins this weekend!
    Dune 500
    YXZ1000R
    Desert kart "Panther" build
    Re: Panther rebuild
    Sep 2016
    Bendigo AUS
    You happen to be in AU one day try smelling Koalas piss. It's an odor not easily forgotten.
    Keep the updates coming please. Loving it.
    Re: Panther rebuild
    May 2015
    Northern California
    Haha, I believe it!
    Started re-assembly today after work. It went smoothly until I tried putting a knuckle onto an a-arm. Turns out the welding had warped the arm enough that I had to adjust the heims. After 30 minutes of fighting with the knuckle, I asked my wife to help me. I jammed a tube into the a-arm end and she flexed the arm while I “slipped” (more like rubber mallet hammered) the knuckle in. It was way too tight so I pulled it out again and am going to do some minor washer adjustments (it’s been so long I had forgotten that was the reason I put washers on either side of each heim joint (for fore and aft adjustment in case the knuckle pivots weren’t parallel). My brother came over and he gave me a hand and we adjusted some of the heims to get it to operate through the arc smoothly, but I think I’m going to turn them back to original settings and adjust washer placement instead to keep wheel alignment correct.
    Pics:
    1. Tonight’s progress.
    2. Cut a spare chain and found a spare master link. 30 minutes of use on left and brand new on right. No difference in length, so that’s good it hardly stretched.
    Dune 500
    YXZ1000R
    Re: Panther rebuild
    May 2015
    Northern California
    5581D61B-96FC-4242-BF37-49E3572A437A.jpeg55A4F7DF-DBCF-4B52-A8A4-261C271661E5.jpegMore assembly. Lost one axle though and found that the knuckles fit with removing one of those steel cap and rubber sealing washers. I put o-rings to keep dirt out on that side. Can’t put wheels on yet due to no axle nut. Limiting straps that I purchased are 25”, and I thought I needed 26”. Turns out that the 25’s work since I cut the chain shorter, making it so the spool moved forward just enough that the cv angle made the joint bind at full droop… so I messed with the heim adjustments and maxxed those out on both sides and still not enough, so I lost about an inch of droop, whatever, at least it’ll work, I hope. The suspension needs to “break-in” again after the welding warped everything, making it all fit tighter.
    Dune 500
    YXZ1000R
    Re: Panther rebuild
    Sep 2016
    Bendigo AUS
    That's looking really good. Apart from the fine tuning it's ready to go.
    Re: Panther rebuild
    May 2015
    Northern California
    Thanks Jim. More I hope tomorrow.
    Dune 500
    YXZ1000R
    Re: Panther rebuild
    Sep 2016
    Bendigo AUS
    Don't tell anyone but the Gixxer fired today.
    I've got my work cut out for me. Lol
    Re: Panther rebuild
    May 2015
    Northern California
    Nice! What’s next on the list?
    I ordered a spare belt today and got the driven pulley with my wonderful wife’s help more aligned by 3/32” to the drive pulley. It’s as close as I can get it without the driven pulley digging into the bearing. It’s still a tiny bit off, but that’s what the spare belt is for. I hammered on the throttle for about 30 minutes and the belt showed no sign of wear or heat damage so I’m crossing my fingers that it’ll hold up in the rough. A plus is the new belt is 1/16” wider (the proper 1-3/16” width that it’s supposed to be) unlike the current 1-1/8” wide belt. Seat belt lap-belt portion mounted, hoping to pick up a new axle nut tomorrow since I lost one…
    Dune 500
    YXZ1000R
    Re: Panther rebuild
    May 2015
    Northern California
    My wife helped me bleed the brakes yesterday, and I made a skid plate to protect the sprocket. I wouldn’t bash on it all day long, but it should be sufficient. I did a quick warm-up with the tires off, and ran it up to full RPM with the pedal all the way down. On the box it says max rpm is 4000 or so, I am getting 3980 maxed out. Pretty darn close. Mounted the brake lines in rubber grommets. I did the top portion of the seatbelt. I am hoping today to open up the skid plate a bit for more sprocket clearance, paint it, and it should more or less be done, other than minor adjustments.
    Pics: Skid plate before paint. .090” steel.
    Dune 500
    YXZ1000R
  1. Panther
    By CaseyZ in forum How To Do It
    Last Post: 05-13-2013, 12:48 PM
  2. the rebuild is done
    By weekend warrior in forum MiniBuggy.net Lounge!
    Last Post: 09-26-2012, 07:46 AM
  3. Panther!
    By fireboy in forum Projects in Progress
    Last Post: 05-03-2012, 07:26 PM
  4. 9 car rebuild. All Done.
    Last Post: 01-04-2009, 06:53 PM
  5. VW IRS on a Panther?????
    Last Post: 12-10-2007, 04:08 PM
