Thread: Panther rebuild
Page 14 of 14 FirstFirst ... 4 12 13 14
Results 131 to 139 of 139
    Re: Panther rebuild
    May 2015
    Northern California
    Picked up a sand rail with a Ford Capri 2.6L V6 with a 4 barrel on it. Seems to run decent. Couldn’t pass it up… not too much Panther progress this week as it’s still endless summer heat here.
    Dune 500
    YXZ1000R
    Desert kart "Panther" build
    Re: Panther rebuild
    May 2019
    California
    Looks fun. I had a rail during college and we had lot of fun with it and that's part of the reason for my build right now. We had a VW 1600 and I probably spent 2-3 hours working on it for every 1 hour of driving it. Was still worth the experience at the time. Having a Ford power plant should be better and I'm sure will generate smiles and bugs in your teeth equally as well.Panther rebuild
    Re: Panther rebuild
    Quote Originally Posted by XJZ33 View Post
    I probably spent 2-3 hours working on it for every 1 hour of driving it. Panther rebuild
    Yeah, I resemble that remark. For the longest time, it felt like I spent more time working on my buggy than riding it. It wasn't a total negative, however. You learn by doing, right? I broke an axle back in March, but I think I have the last of the gremlins worked out after the engine (and axle) swap.
    Re: Panther rebuild
    May 2015
    Northern California
    Sounds like my past experiences with many Volkswagens too… hoping it’s reliable!
    More on topic; still a bit stumped on the upper shock mount bracket. I started cutting out a rectangle tube but have only got one side cut as a mock up so far.
    Dune 500
    YXZ1000R
    Re: Panther rebuild
    May 2015
    Northern California
    Check it out! All steel body. I had hopes of making this 4WD, but the axles I wanted to use got sold so most likely it will be 2WD. Talk about sidetracked from my original project…
    Panther rebuild update: My cousin kindly offered to let me borrow his mandrel bender; which I’m excited to use and create shock hoops for the rear. Should look cleaner than my original idea (rectangular tubing cut at angles and braced). This also allows me to get my moneys worth from the tube notcher.
    Dune 500
    YXZ1000R
    Re: Panther rebuild
    What is that?
    Looks really retro.
    What’s the power plant?
    It needs a flux capacitor.
    Re: Panther rebuild
    May 2015
    Northern California
    It’s a Taylor Dunn warehouse cart/mini pickup. Originally was 36v, but had a cooked commutator, so a “spare” 13hp engine is going in, along with a 3-4” lift and 22” tires. Flux capacitor is after testing to see if it holds together or not.
    Dune 500
    YXZ1000R
    Re: Panther rebuild
    May 2015
    Northern California
    Been super busy with work and life lately, but Merry Christmas to everyone! Still at a pause on shock hoops for buggy, but I should have more time once it starts raining.
    Dune 500
    YXZ1000R
    Re: Panther rebuild
    Duck in a Tux jimmyg's Avatar
    Sep 2016
    Bendigo AUS
    Don't have much free time myself. Fully understand.
  1. Panther
    By CaseyZ in forum How To Do It
    Last Post: 05-13-2013, 12:48 PM
  2. the rebuild is done
    By weekend warrior in forum MiniBuggy.net Lounge!
    Last Post: 09-26-2012, 07:46 AM
  3. Panther!
    By fireboy in forum Projects in Progress
    Last Post: 05-03-2012, 07:26 PM
  4. 9 car rebuild. All Done.
    Last Post: 01-04-2009, 06:53 PM
  5. VW IRS on a Panther?????
    Last Post: 12-10-2007, 04:08 PM
