Thread: Panther rebuild
Page 13 of 14 FirstFirst ... 3 11 12 13 14 LastLast
Results 121 to 130 of 137
    Re: Panther rebuild
    Duck in a Tux jimmyg's Avatar
    Sep 2016
    Bendigo AUS
    If your thermostat works cooling is is a safety margin. Bigger is better.
    I have gone twins with clean air.
    Re: Panther rebuild
    Sep 2016
    Bendigo AUS
    Re: Panther rebuild
    May 2015
    Northern California
    And dual fans even…
    I’ll see if I can squeeze the civic radiator in between the cage tubes.
    Dune 500
    YXZ1000R
    Desert kart "Panther" build
    Re: Panther rebuild
    The Wizard of Welding kustomfab2003's Avatar
    De Pere, WI
    Biggest issue is airflow. On a street bike configuration, the radiator is directly in front of the bike and it also has the fairings to direct the airflow as well (most not all bikes). Once you move the motor and cooling source to the rear of the buggy airflow is reduced greatly and accommodations for location and size need to be made. I went with twin Civic radiator with fans and will be having scoops added to my body panels to direct more airflow to the rear as well.
    CWI CWS CWE
    Re: Panther rebuild
    May 2015
    Northern California
    I’ll keep that in mind, thanks!
    Edit: After cycling the arms, it looks like I’ll be able to get 11-12” travel in the rear; which more or less matches the front.
    Dune 500
    YXZ1000R
    Re: Panther rebuild
    May 2015
    Northern California
    Column crossbar tacked in.
    Tested the KLR cooling fan and it works. I’m leaning toward an 05-06 Kawasaki zzr600 radiator as that bike puts out over double the HP of the KLR, is considerably larger, and also a nice size with a curve (albeit smaller than the civic radiator) with convenient inlet and outlet.
    Dune 500
    YXZ1000R
    Re: Panther rebuild
    Sep 2016
    Bendigo AUS
    I felt it import to make an effort in your thread also. It's very enjoyable to see progress on your build. It inspires me to work on mine.
    Thankyou
    Re: Panther rebuild
    May 2015
    Northern California
    Thanks Jim! Welcome! I’ve been enjoying your build thread also. Love all the ingenuity and ideas here.
    Dune 500
    YXZ1000R
    Re: Panther rebuild
    Sep 2016
    Bendigo AUS
    Well you make the effort to. Keep it up. Respect.
    Re: Panther rebuild
    May 2015
    Northern California
    Thanks.
    No pics yet, but I’ve made a few small shock brackets for the rear.
    Dune 500
    YXZ1000R
  1. Panther
    By CaseyZ in forum How To Do It
    Last Post: 05-13-2013, 11:48 AM
  2. the rebuild is done
    By weekend warrior in forum MiniBuggy.net Lounge!
    Last Post: 09-26-2012, 06:46 AM
  3. Panther!
    By fireboy in forum Projects in Progress
    Last Post: 05-03-2012, 06:26 PM
  4. 9 car rebuild. All Done.
    Last Post: 01-04-2009, 05:53 PM
  5. VW IRS on a Panther?????
    Last Post: 12-10-2007, 03:08 PM
