Thread: Panther rebuild
Page 12 of 14 FirstFirst ... 2 10 11 12 13 14 LastLast
Results 111 to 120 of 137
    Re: Panther rebuild
    May 2015
    Northern California
    Both sides tacked up. Spent lots of time on the left side and mirrored it for the right side. Too hot for more tinkering today, 109 degrees out.
    Dune 500
    YXZ1000R
    Desert kart "Panther" build
    Re: Panther rebuild
    May 2015
    Northern California
    More roll cage progress. Shock mounts next. Picked up a ton (literally) of steel cut-offs of odds and ends from a fab shop for really cheap (he said I did him a favor actually by hauling them away). Should come in handy.
    Looks like the new 10” travel Fox shocks will be a better fit than the 12” travel ones.
    I’m thinking the shocks should be perpendicular to the arms at full bump for max bottoming resistance, ride height at 30-ish percent of shock travel, and the arm-side mount as far “outboard” as practical for best damping control. Preload is nitrogen adjustable, damping isn’t adjustable (other than fluid weight and valving I think; which I don’t plan on messing with if it rides reasonably). I was originally aiming for 8-10” rear travel, but looks like I can get 12” or more. Did I miss anything?
    Dune 500
    YXZ1000R
    Re: Panther rebuild
    It looks like you're making good progress. Did you miss anything? Not sure, but when you're almost finished, all the things you missed will suddenly be apparent.
    Re: Panther rebuild
    May 2015
    Northern California
    Ha! That’s what I’m hoping to avoid… surprises. I realized yesterday that I didn’t incorporate any rake into the pivot points on the rear suspension, although I have about 2 degrees of nose up at ride height. Oh well, the show goes on!
    Dune 500
    YXZ1000R
    Re: Panther rebuild
    May 2019
    California
    I was talking to a co-worker today who races ultra4 about getting some new shocks for my buggy. He said with the economy the way it is currently he would expect a 6-9 month lead time on shocks that are ordered right now. I about had to pick my jaw off the ground. I hope you already have your shocks in hand, as I dont.
    Your progress is looking good. It's always nice realizing you can get a little more travel out of your setup.
    Re: Panther rebuild
    May 2015
    Northern California
    Holy moly 6-9 months is long enough for me to mine all of the materials and build shocks myself. Thankfully, I do already have shocks, which I picked up from another member. What type and travel numbers on the shocks do you need? I can keep an eye out here as every once in a while some pop up.
    Dune 500
    YXZ1000R
    Re: Panther rebuild
    May 2015
    Northern California
    Greasable sway bar bushing for the column.
    Dune 500
    YXZ1000R
    Re: Panther rebuild
    Duck in a Tux jimmyg's Avatar
    Sep 2016
    Bendigo AUS
    Clever!!!! A++ for you.
    Re: Panther rebuild
    May 2015
    Northern California
    Thanks Jimmy! Hoping to get another hour or two to fab the column mount tube tomorrow.
    Dune 500
    YXZ1000R
    Re: Panther rebuild
    May 2015
    Northern California
    Looking into radiators. I have a dual row aluminum Civic radiator, but it seems overkill and huge for the 650cc single. Would a radiator from say, a Kawasaki zx6 ninja be enough capacity? It’s curved and looks like it’d fit nicely. I figure it cools 110hp 4 cyl, it should be enough for a 40hp single.
    Dune 500
    YXZ1000R
  1. Panther
    By CaseyZ in forum How To Do It
    Last Post: 05-13-2013, 11:48 AM
  2. the rebuild is done
    By weekend warrior in forum MiniBuggy.net Lounge!
    Last Post: 09-26-2012, 06:46 AM
  3. Panther!
    By fireboy in forum Projects in Progress
    Last Post: 05-03-2012, 06:26 PM
  4. 9 car rebuild. All Done.
    Last Post: 01-04-2009, 05:53 PM
  5. VW IRS on a Panther?????
    Last Post: 12-10-2007, 03:08 PM
