Results 11 to 20 of 30
    Re: Matt's Cross Kart Build
    Quote Originally Posted by 67StingrayJ View Post
    I see the green prototype in the back. Are these your design?
    Yep. Holds a BMW 335I rear bearing. Plan is to use the bearing, hub, and axle assembly from the 335i to cut down on custom parts. And its easy to replace.
    How did you end up deciding to use a BMW 335I components? I like it, but just want to understand.
    HARD WORK PAY$
    The inner CV mounts flush and the outer has a stub on it. Some are the other way around or have some goofy inner CV style. This allowed me to keep the inner CV to CV dimension narrow which narrows up the suspension etc. I think i measured about 1.5" of plunge also. and 65$ each! SURTRACK / TRAKMOTIVE BM8754
    Quote Originally Posted by Matt View Post
    This probably would not be a good option for a long travel buggy since the cv doesn't have great articulation, This build only needs 6-8" or rear travel.
    Starting the mount for the rear end (yellow in picture). The center bearing carrier will mount to this bracket and swivel to adjust chain tension. Starting with a 10 lb block of hot rolled steel! And yes I'm using some of these parts as an excuse to become more practiced at machining
    I enjoy whittling away 80-90% of the weight out of billet blocks.
    Good looking work.
    what's your preferred CAD software? Looks like your maybe using inventor? or is that SolidWorks? Other?
    HARD WORK PAY$
    I've used a few. NX, Inventor, Creo, Solidworks. They all get the job done, but after spending 1000's of hours using CAD at work, for my personal copy I bought a lifetime Solidworks license. I spend much less time on SW trying to figure out how to navigate the interface and more time focusing on the part or assembly. NX is great because the part file is the same as the drawing file. I love the mouse gesture feature in SW, just flick the mouse in a direction to get a different tool activated, very fast. I've been meaning to make a short vid on how I make part models to help take some of the intimidation out of CAD for the guys who haven't tried it yet. I know these videos are out there generally, but it would be cool on a minibuggy part.
    Got it done, took about 4 hours, not too bad. from 10lbs to 2.7, Missed a fillet, but it should be fine. Nice to get all that work on the rear end on the frame for the first time. If I break this assembly I'll be very surprised!
    I see what you're up to now. Very nice!
    "Missed a fillet, but it should be fine"
    AHHAHAHAHAHAHAHA!!! It's not just me that does stuff like that! YAY!!
  1. Formula Cross(Rhys Millens new kart class)
    Last Post: 05-09-2014, 09:01 AM
  2. My Kart Cross design
    By bigblock in forum Projects in Progress
    Last Post: 08-07-2011, 04:57 PM
  3. Kids Kart Build
    Last Post: 12-27-2010, 04:38 PM
  4. Kart cross
    Last Post: 12-30-2008, 08:59 AM
  5. kart cross verses audi
    By nutnbolt2002 in forum Minibuggy.net News
    Last Post: 08-06-2007, 10:46 AM
