Page 6 of 6 FirstFirst ... 4 5 6
Results 51 to 58 of 58
    Re: ProtoDie SS1000 build
    #51
    May 2013
    Easton, PA
    Very cool, there's a geodesic home near me for sale that I looked at, not quite enough land for what I'm after and the wife doesn't like the looks of the house design-wise ...
    #52
    De Pere, WI
    Thanks. It has taken some getting used to and some "creative" staging. We are on just over 5 acres that actually back up to 20+ acres.
    CWI CWS CWE
    #53
    De Pere, WI
    So... after many months I was finally able to get in some time on the buggy parts last night. I have been gathering parts, but hadn't taken the time to fabricate any (didn't help that my shop door was frozen to the ground . Anyway finally was able to cur out the other side plates needed for the rear suspension uprights. I am using 1/2" grade 8 hardware, but the hole fit was still a bit snug, so I ordered me a 13mm bit .5118" that should be just enough to slide in nicely. Everything has been cut on my Swag Offraod porta-band table. Material is 1/4" thick... a bit beefy, but should show any failures. The bottom hole is not crooked, just the camera angle. I assure you everything is straight.
    Both Pieces stacked on top of each other, not a bad fit overall.
    CWI CWS CWE
    #54
    Dec 2014
    Detroit, MI
    What are your reviews on that Bauer portaband on the SWAG Table?
    I've been looking at doing that same setup
    #55
    De Pere, WI
    "What are your reviews on that Bauer portaband on the SWAG Table? I've been looking at doing that same setup"
    So far it has done very well. Mine is about 2 years old now. I have cut everything from gauge metal to 1/4" mild steel as well as 3/8" aluminum without any problems. Only limitation might be the depth you are able to cut. Not sure what the newest latest and greatest is, but the Swag-Offroad site should have details. I have been using the blades from HF as well. So far I only broke 1 and that was pressing and turning hard into some 4130 plate...
    CWI CWS CWE
    #56
    De Pere, WI
    Lot's of progress pic's. Not using the Covid-19 as time to fab as I am essential and still work during the week...Rear buggy uprights are complete. I showed my apprentice how to finish grind the support plates that I plasma cut out. All GTAW (TIG) welded with the power of Blue. Couple more just because. Power plant is a 2010 Kawasaki Z1000 street bike engine. Chain drive to a FNR, Forward-Neutral-Reverse gearbox, then 930 Porsche CV’s for the drive axles. The rear suspension mock up begins Finally... but there was one snag, but a simple fix. When I drew out the upright templates, it was based on a Fox 2.0 air shock. Now I am going to be running Elka 2.5" coilovers... Needless to say the Elka's are a bit more beefy and use a 3/4" uniball at the pivot instead of a 1/2" uniball. Simple fix, I will cut off the upper ears and replace them with longer ones, while I am at it I will be adding welded in spacers to minimize any shock play.
    [url=https://imgur.com/cTHvQgt]
    [/url[url=https://imgur.com/LH0r47v]
    [/url[url=https://imgur.com/jpvBkvL]
    [/url[url=https://imgur.com/lzeKkx7]
    [/url[url=https://imgur.com/i9VMWpC]
    [/url[url=https://imgur.com/XE2E1Iq]
    [/url[url=https://imgur.com/X9tHstT]
    [/url[url=https://imgur.com/nicdDPT]
    [/url[url=https://imgur.com/0syIHpw]
    [/url[url=https://imgur.com/l2fBaSf]
    [/url[url=https://imgur.com/TuDNF10]
    [/url[url=https://imgur.com/1URKOY0]
    [/url[url=https://imgur.com/p2dp2xS]
    [/url[url=https://imgur.com/o0LH3wU]
    [/url[url=https://imgur.com/t9bTBiS]
    [/url
    CWI CWS CWE
    #57
    De Pere, WI
    Not all the pictures posted for some reason, but you get the point. A-Arms will be out of 1 1/4" .120 wall DOM material. Heims at the wheels are 3/4", the ones at the bulkhead are 1/2" because of the way the cage was made already...
    CWI CWS CWE
    #58
    Senior Member jimmyg's Avatar
    Sep 2016
    Bendigo AUS
    Got to be happy with how they came out. I know I would be.
  1. Protodie SS1000 Project
    By Croush20 in forum For Sale
    Last Post: 10-17-2019, 02:08 AM
  2. SS1000 Protodie project
    By 98Blazer in forum For Sale
    Last Post: 05-14-2019, 11:02 PM
  3. Basic Protolite SS1000 Frame Build
    By bryzoe in forum SS1000 - Two Seat Race Buggy
    Last Post: 06-27-2018, 03:27 AM
  4. My Protodie build
    By monkeyinfantry in forum SS1000 - Two Seat Race Buggy
    Last Post: 11-01-2017, 03:29 PM
  5. Protodie Build
    By Croush20 in forum SS1000 - Two Seat Race Buggy
    Last Post: 06-03-2013, 11:28 AM
