Page 2 of 10 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 91
    Re: ProtoDie SS1000 build
    Brakes have arrived. After reading so many clearance issues stories, I began to doubt my measurements, LOL. I have LOTs of clearance. Bare rotors and calipers. Caliper clearance on wheels: Rotor Clearance: Overall View:
    CWI CWS CWE
    Ok... Why does my text keep getting skewed to the right??? It doesn't seem to matter how I format or use spacing, my commentary for the pictures is always off....
    CWI CWS CWE
    Quote Originally Posted by kustomfab2003 View Post
    Would you mind posting manufacturers part numbers and where you bought these from? Possibly what you paid?
    https://www.ebay.com/itm/Bolt-on-Sup...AAOSw2XJbjgnrI specified the ball joint front end. They do have a combo spindle as well available but sometimes there are bearing conflicts and I just didn't want to deal with it.https://www.ebay.com/itm/2-A-arm-spi...SwJrpdQR07This is the weld together spindle kit. I have used it on several buggy builds over the years with great success.
    CWI CWS CWE
    My A-Arms will be out of 1 1/4 DOM material and the fronts will have 3/4" Rod ends (12 total) at all ends with the high misalignment spacers to use a 1/2" bolt. Since the rear cage is already welded by ProtoDie i will use 3/4" (8 total) rod ends at the wheel side of things and 5/8-18 threaded rod ends with a 1/2 hole on the cage side (8 total)...By Chance does anyone have the dimensions (drawings) for the RPM mounting brackets that were supplied by ProtoDie and the spacer spacing?? Since Jodie has moved on in his career, his business is for sale so he has turned off all orders on his site.
    CWI CWS CWE
    Senior Member Beruba's Avatar
    Feb 2014
    Alberta Canada
    plates & washer are 1/4" thick
    The distance between the holes in the plates are
    6-1/4"center to center
    5-1/4" center to center
    1-1/2" center to center
    the washer are
    3/8" id
    1-1/4" od
    the tubes are 5/8" od 3/8" id ( you can use 3/8" pipe nipples)
    the long ones are 3-9/16" long
    the short ones are 1-1/2" long
    hope that help if you need other measurements let me know
    Feb 2014
    Alberta Canada
    Also there's only 2 holes on the plate to hold the steering rack you should drill a couple more & use the threaded holes of the steering rack.
    this way you have 4 bolts to hold it in place.
    Thanks!!! I did plan on using all 4 holes :-).
    CWI CWS CWE
    OK so I know how everyone is about pictures on the build pages (I am the same way). Had some time this afternoon to work in the shop since the thunderstorms rolled in. Here are some pic's of the first spindle getting prepped and welded up. My Dynasty never lets me down!! It's probably been over a year since I have had a chance to sit down behind the TIG torch. I still need to get a smaller torch as the #17 is just way to large for tight spaces.
    CWI CWS CWE
    Sep 2008
    Allendale MI
    Beautiful welds! I love the steel prep as well. A HUGE step in proper welding.
    Justin
    Nowhere near the desert.
  1. Protodie SS1000 Project
    By Croush20 in forum For Sale
    Last Post: 10-17-2019, 02:08 AM
  2. SS1000 Protodie project
    By 98Blazer in forum For Sale
    Last Post: 05-14-2019, 11:02 PM
  3. Basic Protolite SS1000 Frame Build
    By bryzoe in forum SS1000 - Two Seat Race Buggy
    Last Post: 06-27-2018, 03:27 AM
  4. My Protodie build
    By monkeyinfantry in forum SS1000 - Two Seat Race Buggy
    Last Post: 11-01-2017, 03:29 PM
  5. Protodie Build
    By Croush20 in forum SS1000 - Two Seat Race Buggy
    Last Post: 06-03-2013, 11:28 AM
