Page 13 of 13 FirstFirst ... 3 11 12 13
Results 121 to 130 of 130
    Re: ProtoDie SS1000 build
    Senior Member Linden318's Avatar
    Jun 2015
    Alberta, Canada
    NICE! That sure looks great. It is hard to see but what kind of angle is the u-joint on the steering rack operating at? Looks like it is fairly sharp but it may just be the photo angle. From experience, I have found that with the u joints at a high angle, you get a quick-slow motion while turning. Sure youre aware but I thought Id see how its set up! Awesome work.
    I am looking forward to see how you set up the pedal assembly. I am looking for a throttle cable for my built that could run from throttle bodies all the way to foot pedal. The current setup I have I have found has a lot of friction and the pedal is heavy.
    Quote Originally Posted by Linden318 View Post
    NICE! That sure looks great. It is hard to see but what kind of angle is the u-joint on the steering rack operating at? Looks like it is fairly sharp but it may just be the photo angle. From experience, I have found that with the u joints at a high angle, you get a quick-slow motion while turning. Sure you’re aware but I thought I’d see how it’s set up! Awesome work.
    The camera doesn't help the angle appearance, but they aren't a mild angle either. some are just under being maxed out as far as smoothness of steering. I had to play with the support bearing angle quite a bit to eliminate any binding or "flip" associated with the angles as well as pay close attention to phasing in the universal joints. Time will tell.... I may have to spend son big $$ on the high end universal joints, but right now, with out power connected, the steering is smooth in both directions.
    CWI CWS CWE
    Jun 2015
    Alberta, Canada
    Quote Originally Posted by kustomfab2003 View Post
    Awesome! Good to hear. How have you clocked your u-joints? I took a guess on how to do this when I set up mine and this could be the reason I get a quick-slow Steering feel.
    I did a google search on clocking or phasing of u-joints and received a bit of assistance. They recommend that if there is a bind pint, to turn the universal 2-3 splines in the direction that reduces the binding. I have also noticed the factory universals have been clearanced where the stock over the counter one have not been. I may take a Dremel and lightly buff out the edges where contact might be made, but right now there isn't any binding.
    CWI CWS CWE
    Jun 2015
    Alberta, Canada
    Yes that makes sense. I never did have any binding but I still find it steers quick and slow. Well see if I can find more info online about that.
    Oh yes I did ur a dremel and slightly open up my u joint I had purchased also. I found the factory Nissan I joints were run at very high angles! I see you are finding the same thing with the Prius joints.
    Somewhere in the Mini-Raptor thread I addressed "porting" the u-joints I'm running. I got another 10 - 15 degrees of articulation by clearancing any place that the u-joints bound until they gave me enough. I can't find pix - know I have them somewhere. I'm definitely running over max design - saw dual u-joints after I got everything set up. I'd have put one on the top of the steering column and designed it to work around that but now that it's set up, the pivot point would be wrong so it's a no-go.
    I need to do the spline at a time clocking check - have a tight spot and also have speed up/slow down happening. The little power steering box takes all the effort out of the system, though.
    It's wild to go back through the MR's build thread. It's sitting there in the shop now, waiting on headers so I can take it out and start to play. I see pix of it from a couple years ago and realize just how much shit I've stuffed into that chassis.
    So, I've been bouncing around in my head what to do about body panels... The Mini Raptor conversions dimensions just didn't match up wheelbase wise and the roof line of this cage was really suited for that kind of bodywork. After much ADD inspired googlefu I settled on some Teryx plastics (partly because this is Kawasaki powered). I received my 2013 set from eBay today and proceeded to measure, cut, trim, measure and then massage the front end with the heat gun to make a fit I am pretty happy with. I also started on the rears, but still have much to go. Aluminum work will have to be done to tie into the body etc....
    CWI CWS CWE
    Senior Member jimmyg's Avatar
    Sep 2016
    Bendigo AUS
    Epic!
    Senior Member lost26's Avatar
    Highland Village Tx
    Looks awesome!
    For those that don't follow on Facebook or are just looking for updates in one area, here are some of the updates of the body panel work I have started on the ProtoDie. This is my first attempt at making my own panels and I have lot's of room to grow.
    Cardboard templates being cut to size and design layout:
    Transferred the template to aluminum sheet and started forming with the slip roll:
    Edges were bead rolled to add contour and tacking began:
    Moved onto the door panel since I ran out of Argon to finish the welding up:
    Some pictures of it outside right after I got the rear fenders mounted in place:
    CWI CWS CWE
  1. Protodie SS1000 Project
    By Croush20 in forum For Sale
    Last Post: 10-17-2019, 03:08 AM
  2. SS1000 Protodie project
    By 98Blazer in forum For Sale
    Last Post: 05-15-2019, 12:02 AM
  3. Basic Protolite SS1000 Frame Build
    By bryzoe in forum SS1000 - Two Seat Race Buggy
    Last Post: 06-27-2018, 04:27 AM
  4. My Protodie build
    By monkeyinfantry in forum SS1000 - Two Seat Race Buggy
    Last Post: 11-01-2017, 04:29 PM
  5. Protodie Build
    By Croush20 in forum SS1000 - Two Seat Race Buggy
    Last Post: 06-03-2013, 12:28 PM
