Results 1 to 10 of 13
    2 seater long travel buggy
    Dec 2011
    quebec canada
    We started building this buggy back in 2013. It was originally supposed to be an st4 with megalodon suspension but since a lot have changed. I had started a thread in the badland badland buggy forum but all the picture disapeared and since it is not reaaly a badland anymore i wanted to stard a new thread. The front suspension is the megalodon suspension and the rear is our own design. 20 inch of travel font and rear.
    Engine: kawasaki zx11
    Reverse: modified mxz 1200 chaincase
    Re: 2 seater long travel buggy
    Jan 2015
    Norco, CA
    looks good, more on the modified mxz 1200 chaincase please
    Dec 2011
    quebec canada
    the chaincase normally have only an input shaft and an output shaft so we had to drill a hole the other side then had a bearing and a seal and a bearing holder. It is bolted on because the chaincase is made of magnesium so we can't weld it.The plate on each side are there to prevent the chaincase to bend in half.
    The other side use the original bearing and seal.
    The cv are welded to the original shaft of the chaincase. The cv are from chevrolet cavalier also modified so that we use the part of the cv that goes to the wheel since it has can bend more tha the side that normaly goes in the trans.
    using that setup we get the pivot at 6 1/2 inch.
    modified hub
    Dec 2011
    quebec canada
    Mounting the brake caliper
    Dec 2011
    quebec canada
    update a lot have been done since my last post the buggy is 90% finished et juste need to finish the welding. some picture of the buggy on its wheels!
    Senior Member jimmyg's Avatar
    Sep 2016
    Bendigo AUS
    Beast! Going to take a bit to break that!
    Sep 2014
    West Palm Beach FL
    Love it
    I recognize that engine. Do yourself a favor and be on the lookout for a bypass oil pan. I also have a pretty nice header that you might like that wraps around on the right side rather than under. Might be able to hook you up with some other parts too.
    All you got to do is remember 2 thing, Mentum and Mo-Mentum.
    Dec 2011
    quebec canada
    Quote Originally Posted by sosasser View Post
    I have looked online but what do the bypass oil pan do?
    Dec 2011
    quebec canada
    the modified chaincase in the buggy.
  1. ST 2 Long Travel Buggy
    By JohnT in forum ST2
    Last Post: 02-09-2014, 12:16 PM
  2. 2 seater I'll be adding long travel to
    By krey910 in forum Projects in Progress
    Last Post: 01-05-2013, 08:36 PM
  3. Replies: 4
    Last Post: 05-16-2012, 04:26 PM
  4. Tom's: Long Travel Buggy
    Last Post: 08-28-2011, 07:54 PM
  5. narrow long travel 2 seater, is it possible??
    By bigmikem35a2 in forum Frame
    Last Post: 03-15-2011, 08:12 PM
