Results 1 to 7 of 7
    Buggy is setup for hydraulic clutch, engine has cable clutch...solutions?
    Jun 2015
    Texas Panhandle
    Old engine used a hydraulic clutch, the 954RR engine iím using is cable.
    my options as i see them are to try and figure out a way to adapt a hydraulic clutch to the cbr or have someone build me a 15 inch cable and change my pedal setup completely.
    how would you guys attempt to address this?
    Re: Buggy is setup for hydraulic clutch, engine has cable clutch...solutions?
    Look and see if Magura makes a hydraulic conversion for it. They did a lot of them. It adds a small slave that bolts into the spot where the cable mounts and then runs a hydraulic line to the master cylinder.
    https://www.magura.com/en/components...ilpage/?p=1853
    Jun 2015
    Texas Panhandle
    Only 300 euros! Lol
    makes me wonder why i can’t just use the slave on the buggy on a bracket to turn the lever...
    eBay. You should be able to find a slave.
    https://www.ebay.com/sch/i.html?_fro...inder&_sacat=0
    Slave cylinder. Speedway motors.
    I made a little U goes on end bolts to arm on bike. Other end to a solid mount on frame. Run hydrolic line and boom. Just adjust so you don’t over pull arm. May have to put a pedal stop
    Jun 2015
    Texas Panhandle
    I’ve been thinking along those lines but was afraid of overpowering the arm. Got a picture of your setup?
    They make hydraulic to cable conversion kits for honda civics you might be able to make kne of tjose work
  1. converting cable clutch to hydraulic clutch
    By jeff118589 in forum Motor - Engine
    Last Post: 04-21-2013, 06:21 PM
  2. hydraulic clutch
    By GrossGraphix in forum Controls and electrical
    Last Post: 01-10-2013, 08:38 PM
  3. Hydraulic clutch line??
    By rob8420 in forum Controls and electrical
    Last Post: 06-05-2012, 04:16 PM
  4. Hydraulic Clutch
    By mal180 in forum Controls and electrical
    Last Post: 05-26-2012, 07:01 AM
  5. Hydraulic or Cable clutch connection?
    By TutTech in forum Controls and electrical
    Last Post: 07-12-2011, 08:24 AM
