Results 31 to 38 of 38
    Re: Redline Revolt rebuild / modify
    #31
    Mar 2018
    Central Ohio
    Hey K, Thanks for the feedback on the shocks.
    On another note...I found a piece of rectangular tube in my pile of scraps and made a trial spreader so the upper rear transverse links could be shortened (get more camber gain) like you mentioned above. I only ran it for a couple hours on a small track. But WOW what a difference it made, FAR MORE than I was expecting. It felt weird at first because it changed the "out of corner" handling, but after a coupe of laps I got used to it. It was the first time I could actually "set" the rear end, keep it pegged and have it stay where I put it on the bank, until I came out the other end. I am assuming (but haven't checked yet) that by moving the upper inner mounting points forward and not the bottom mounting points, that I changed the amount of compression toe in that is there normally. once I get the new brackets put on and both mounting are moved forward I can verify.
    #32
    Nice, camber gain good........
    #33
    Toe isn't going to change (much - anything noticeable) - it's set by the trailing arm/carrier.You're playing with the transverse links. The upper one, now being shorter, makes the camber increase as the suspension compresses because the upper mount is on a tighter radius than the lower, hence pulling the top of the carrier in as it cycles. It'll do the same as it droops out too, which is desired - keeps the scrub down some.It's letting the wheels keep the contact patch better placed and not allowing the wheel to roll out over/away from the contact patch. Instant traction.
    #34
    For reference.
    Congrats, been waiting for someone to to fix the rear of one of these things and tell us how it goes.
    #35
    Mar 2018
    Central Ohio
    Hey Bull,
    Your pictures are appreciated, keep them coming. It's been 30+ years since I've turned wrenches or messed around with buggies. Visual aids are great.
    PM sent.
    #36
    Mar 2018
    Central Ohio
    Moving on to the front end...
    While gathering the front end info I identified the following...
    • Total front end weight is 250#, 125# per corner
    • Disconnected the shock, set at ride height and found the unsprung weight to be 50# per corner (40% of corner weight)
    • Tire & rim weight is 30# each
    • Motion ratio is .87:1 (not considering shock angle)
    Wondering what others have done to deal with high unsprung weight ?
    #37
    Lighter rims, like Douglas Red Labels - what do the cast wheels weigh?
    Lighter tires - but what?
    I wonder how much the motion ratio changes as the suspension cycles? I can’t recall how much the shocks are laid over.
    Might be chasing a bit of a ghost presently instead of working with geometry to make things happen better first.
    #38
    Mar 2018
    Central Ohio
    what do the cast wheels weigh?... OEM wheels weight 13#, the tire weighs 17#
    I can’t recall how much the shocks are laid over... 20 Degrees
    Might be chasing a bit of a ghost presently instead of working with geometry to make things happen better first.[/QUOTE]... I agree, I am starting at the tire and working my way inwards.
    I found a website called "racing Aspirations" and have started to play on it. Not certain it will be able to give me the answers I need, but it should give me a better understanding.
  1. WTB Redline Revolt
    By Shir0 in forum For Sale
    Last Post: 01-16-2012, 06:46 PM
  2. My 2007 Redline Revolt
    By bear Foot in forum Show off your toys in here!
    Last Post: 04-06-2009, 10:32 PM
  3. RedLine Revolt
    By stress in forum MiniBuggy.net Lounge!
    Last Post: 02-19-2008, 10:37 AM
  4. Redline Revolt
    By Bedo in forum MiniBuggy.net Lounge!
    Last Post: 09-07-2007, 01:16 AM
