Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
    Re: Not a buggy, but a fun project.
    I decided it needed a step, so I added nerf bars...
    Then, something to pull it around with.
    My daughters each had babies 4 months apart, so naturally I had to make 2 wagons. I am ready to clean up the crappy weld spatter and prep it for paint. I'm still going back and forth on if I want to try Kandy paint, or just metallic. Either way, on will be TCU purple and white, the other apple red and silver.
    Horned Toads!
    Looks good. Can you train them so you can tandem pull?
    I thought about putting a hitch on them and make small trailers for them, but probably won't. Just in case I end up pulling one.
    Re: Not a buggy, but a fun project. FINISHED
    They are done...
    Sep 2005
    Pacific Northwest
    Those came out great!
    Neat!
    How strong is that chain welded up like that?
    "How strong is that chain welded up like that?"Not as strong as I had thought it would be. I guess when you think about it, if you took a rod the diameter of the steel in the chain, it would flex as much, but in my feeble mind, I was expecting more. It will be easy enough to change out for something different if they bend it too much. I used rubber coating on it, so at least I don't have to worry about the paint cracking.
  1. Buggy project
    By 98Blazer in forum Craigslist, E-Bay and Internet listings
    Last Post: 12-22-2017, 01:04 AM
  2. my buggy project
    By fnlfab in forum Projects in Progress
    Last Post: 02-26-2013, 07:18 AM
  3. Ultimate $#@^(Bad word) Buggy Project / The UFB Project
    By Krusekontrol in forum Show off your toys in here!
    Last Post: 04-27-2011, 06:37 PM
  4. FWD to RWD buggy Project
    By BajAMec63 in forum Projects in Progress
    Last Post: 04-22-2007, 10:24 PM
  5. what do you think of buggy project?
    By desertracer543 in forum MiniBuggy.net Lounge!
    Last Post: 12-19-2006, 11:39 PM
