Results 31 to 33 of 33
    Re: Honda FL 440 Build
    #31
    After a lot of small changes, I finally nailed down an expansion chamber design. I'm going to end up having two pipes, which will be a packaging nightmare. I sent the flat DXF files out to be laser cut a few days ago so I should have them back next week.
    #32
    Looks like horsepower to me!!
    I race, therefore I am
    #33
    Axles are bluetooth right now until I get my lengths right. I've read some old threads on here about trailing arms and taken some measurements to try and get the axle length perfect. Looks like I'll have to strap my suspension in order to prevent the axle from pulling out of the spool (I never added a groove for retaining ring).
    From my understanding, at full droop the axle will be "full out" for plunge, and at full bump the axle will be "full in" for plunge/stroke. I do have 2" of plunge built into my spool, which I'm hoping is enough for 18" of rear travel. Last week I rewelded my trailing arm mounts so that my trailing arm CV centerline sits further behind my spool CV centerline.
  1. Honda CR125R Shocks in a Buggy Build
    By darwinpayne2000 in forum Suspension - Wheels & Tires
    Last Post: 03-11-2017, 04:31 PM
  2. 1985 Honda Fl583R build
    By BrandonTKZ in forum Projects in Progress
    Last Post: 09-01-2014, 03:59 PM
  3. honda cbrr 400 build (nc29 engine)
    By mfeinmesser in forum Projects in Progress
    Last Post: 11-13-2012, 05:28 AM
  4. mini rail build with V4 honda VF1000R motor
    By RedDesertCat in forum Projects in Progress
    Last Post: 01-24-2012, 07:05 PM
  5. new build need help with fwd honda setup
    By rsdockler in forum Projects in Progress
    Last Post: 10-19-2011, 12:21 PM
