Figured out how to upload images from Google Photos.
Thread: Manx Busa Build
Results 41 to 43 of 43
- Join Date
- Oct 2018
- Location
- Ft Collins, CO
- Posts
- 21
12-27-2018 01:31 PM
- Join Date
- Oct 2018
- Location
- Ft Collins, CO
- Posts
- 21
11-19-2020 01:35 PM
nice, very innovative setup, I will be curious on how the chain drive holds up.
some things that may or may not be an issue, chains when turning corners tend to make heat, you have alot of corners and with the chain enclosed will it have enough airflow to shed more hear than it produces? if there was a way to male the chain case oil tight you could run it with an oil bath and a small cooler.
one other thing about chains, last year in some wet sand I stretched a section of chain, I am also using the good chain, I believe the same as you are, on the street if you decide to bang gears beware.
thats a great build and I want to see more please keep posting here.
New Build Turbo Busa 2 seater
By fns in forum Show off your toys in here!Replies: 31Last Post: 04-06-2019, 12:56 AM -
Mark's Busa AR51 Build
By Trouble675 in forum AR51 Buggy GroupReplies: 257Last Post: 04-09-2017, 08:22 PM -
Bike powered Manx? Ever see one?
By Bullnerd in forum MiniBuggy.net Lounge!Replies: 25Last Post: 04-18-2015, 08:25 PM -
st4 busa build
By ausj in forum FrameReplies: 3Last Post: 07-29-2012, 06:15 PM -
KrunchWorkz Manx
By KrunchWorkz in forum Projects in ProgressReplies: 40Last Post: 08-28-2011, 04:33 AM
