Page 2 of 12 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 113
    Re: Camping Hack GSXR750 Build.
    Cool the LIL Beast is coming together, good work!
    Apr 2015
    west brabant, netherlands
    i did a build with a similair diff only i machined o pice of round aluminum out to close the gears off from dirt and i doubled as mout for my sprocket an brake disc. however i kept having a problem with the drive splines popping out. how do you plan an solving that?
    for the rest great work man realy liking the look of it, keep it up.
    Duck in a Tux jimmyg's Avatar
    Sep 2016
    Bendigo AUS
    The drive shafts are locked in place by a "C"clip.
    I'm very much hoping not to have to but if they do pop out I will have to cut the grove deeper that will lock them in. Fingers crossed I don't have to as removing would require a big hammers and destroying the "C"clip. One of the many things with a question mark hanging over it. Fingers crossed hey.
    Edit. I'm going to weld up the diff centre to. Makes for better skids.
    Noob comment - but where do you source a diff like the ones in your pictures???
    Sep 2016
    Bendigo AUS
    It's a Rear Subaru r160 diff. Very common and cheap. There are loads of LSD options if you want to go that way also.
    They are a nice press fit for 40mm bearing blocks and once you machine the webs off the back will fit a sprocket.
    PS No such thing as a noob comment. Just a person willing the learn.
    Dec 2012
    Perth, Western Australia
    If you want to (now or in the future) keep the diff unwelded I'm sure there was somebody on here who heat shrunk a 2 litre lemonade bottle around a diff like that, after packing it with grease.
    Sep 2016
    Bendigo AUS
    So keep the diff center open? It will turn better but wo t it kill the drift factor?
    I'm not stressed about sealing the center. More so that it was built as a camping fun machine. I just assumed it would be like a car with an open diff vs a locker?
    Sep 2016
    Bendigo AUS
    Small build update.
    Dec 2012
    Yeah it pretty much is. Mine is locked and seems to me to corner fine. I have read on here about people who have gone from locked to a diff and rave about how much better it turns. For a paddock basher it's a non issue. Just an idea incase an lsd center falls into your lap.
    Sep 2016
    Bendigo AUS
    The VLSD are cheap but the plated are big coin.
    To change it out later is piss easy so all good info to know. Thanks for your help.
  1. Downunder camping/bug weekender.
    By bazz in forum MiniBuggy.net Lounge!
    Last Post: 01-27-2016, 09:07 PM
  2. GSXR750 carb
    By DMoneyAllstar in forum Controls and electrical
    Last Post: 04-30-2010, 12:58 PM
  3. The ultimate VW to go camping!
    By Deranged in forum MiniBuggy.net Lounge!
    Last Post: 04-06-2010, 10:27 AM
  4. lesson learned while camping
    By hansshanks in forum Good stories - Crash and Burn
    Last Post: 07-31-2006, 11:33 PM
