Results 1 to 10 of 11
    150cc Hand Built Buggy (Need Help)
    Post
    Hey Everyone,
    Ive built a buggy in my teenage years from a scooter and parts that i can find.
    It was a 3 wheeler (2 wheels at the front & 1 wheel at the back). I basically slapped in the scooter to the back.
    Now ive pulled it out from the garage and made it a 4 wheeler. Once i sort out everything ill be looking forward to upgrade the motor to something like a GS500 or GPZ500.
    At the moment im working on putting front brakes and trying to solve its bad steering problem.
    While driving it goes in a straight line but as soon as a tyre goes into a small holl or bump it pulls to that side. Im thinking its bump steer but not sure.
    Need some help with this.
    Thanks,
    Re: 150cc Hand Built Buggy (Need Help)
    Apr 2015
    west brabant, netherlands
    The bumpsteer is probably becaus the pivot point of your a-arms isnt in line with the pivot point of your steering rack
    Verstuurd vanaf mijn SM-G930F met Tapatalk
    Thanks for the reply. Im going to work on that and get it line some how. Would you have a photo as a example for me?
    Definitely a bump steer issue along with HUGE scrub radius.
    Read flyerrider's post on front end design and it'll enlighten.
    https://www.minibuggy.net/forum/suspe...uspension.html
    Because you've built a parallelogram front end you'll be able to limit bump steer by moving the inner tie rod mounts out so the tie rods are the same length as the arms but with the massive scrub radius it's going to be a handful to steer and require a lot of input force.
    Needs some caster too, to help the wheels want to center.
    Thanks guys. Really appreciate it. Ill update once i got some progress.
    Post a pic from front center and down low like level w steering. Then we can draw on it.
    No worries ill post that asap. Thanks
    My plan is to give a 8 degree CASTOR and 8 degree KPI.
    Also try to line up the pivot points of the rack with the a arms. What do you guys recommend?
  1. 150cc mini buggy for sale
    By Xbird in forum For Sale
    Last Post: 05-23-2015, 02:59 PM
  2. Replies: 3
    Last Post: 06-12-2012, 02:38 PM
  3. New Buggy Builder Help 150cc
    By ElGuapo in forum Motor - Engine
    Last Post: 08-11-2009, 01:08 PM
  4. mini buggy 150cc
    By big8balls in forum MiniBuggy.net Lounge!
    Last Post: 01-03-2009, 03:51 PM
  5. Hand built Kawasaki 2 stroke radial engine
    By opsled in forum MiniBuggy.net Lounge!
    Last Post: 06-15-2008, 07:15 PM
