Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 48 of 48
    Re: Another off road dwarf car project
    #41
    Junior Member JasonB.'s Avatar
    Jun 2016
    North Alabama
    I'm thinking about the 10" travel Bilstein 6100 valved at 170/60 for the fronts. I've seen a lot of people make reference to the Gabriel shocks and Monroe has a light truck shock with 9" travel, Advance Auto part #
    59037
    , but I can never find valving info for them.
    #42
    Blog Entries
    1
    If you weld a pipe fitting to the top of the can and put in a schrader valve you can rebuild/revalve the Bilstiens pretty easy.
    Top tip, drill a 1/16" hole in the top to release the pressure before you try to take them apart or you will get a bath.
    Edit: with the stock mounts I think you only need like a 6.5" shock.
    #43
    Jun 2016
    North Alabama
    We chopped the factory limiters off and measured the potential travel this weekend. It has the potential for about 9" before binding the tie rods. We got the steel torsion bars put back in and installed the new poly seals on the beam. We also got the brakes cleaned up and everything assembled. Now I'm just waiting on new link pins for final assembly, but they are back ordered. As soon as I get them we will be able to assemble everything and set up the caster angle to build the lower frame and mounts.
    #44
    Jun 2016
    North Alabama
    We are getting close to having the front end finished. we got all new bushings and pins installed and the brakes mounted up. I have to build the lower frame rail and upper shock mounts and we'll be ready to move to the back.
    #45
    The Wizard of Welding kustomfab2003's Avatar
    De Pere, WI
    Nice work!
    CWI CWS CWE
    #46
    Jun 2016
    North Alabama
    Life kicked me in the balls shortly after my last post in 2019. We've since moved, COVID-19 happened, I've taken a new job, and lots of other things. But we finally got back in the shop and got back to work on the buggy. It seems that none of my old photos are still in the thread. I might try to go back and edit some back in. In the meantime, here is a picture from this weekend. We've got the rear mocked up and are getting close to welding it in. I hope we'll be ready to start building an engine by Thanksgiving.
    Here's a short clip of the rack and pinion: https://youtu.be/WNLY-K4Aa-g
    #47
    Welcome back!
    Life gets in the way of shit, doesn’t it. Projects get shelved, rehashed, shelved.
    Yeah, the whole picture thing has been an issue over the years…. PITA
    #48
    "Never give up, never surrender!"
    Glad to see that you're back at it.
  1. Starting Down the Long Project Road
    By Brody in forum The Welcome Mat
    Last Post: 01-13-2014, 08:33 PM
  2. Dwarf 49 Merc
    By Rat4020 in forum MiniBuggy.net Lounge!
    Last Post: 02-23-2013, 09:28 AM
  3. off road buggy project help
    By miniracer1962 in forum Projects in Progress
    Last Post: 09-21-2011, 09:25 AM
  4. Gsmoon 260-2 road legal buggy project in Finland.
    By Rossar in forum Show off your toys in here!
    Last Post: 04-27-2011, 01:09 PM
  5. Dwarf car conversion
    By Raptoryan in forum MiniBuggy.net Lounge!
    Last Post: 09-07-2009, 02:30 PM
