Results 11 to 20 of 23
    Re: PLS HELP lol. Buggy rear end.
    Aug 2016
    St Catharines, ontario, Canada
    sorry man do you mean the bearing carrier behind the hub that holds the wheel or do you mean up by the frame where the rear sprocket is? sorry.
    Aug 2016
    Aug 2016
    the original setup had a splined shaft through the main sprocket and the cv's attached to it
    the previous owner took out the splined shaft and put a keyway in
    Oct 2008
    Ontario, Canada
    Quote Originally Posted by Dannyc View Post
    The inner hubs that would connect to your center shaft (where the u-joints would be connected)
    Aug 2016
    Not sure what ya mean, here is the original, let me know which part. I know you don't mean the hub that holds the rim
    Aug 2016
    I went and got u joints last night to copy your setup on the build you posted
    Aug 2016
    I finally got drive shaft installed they are huge and look to be able to take a beating. best part they fit perfectly in the Carter GTR
    Aug 2016
    I need to change the title of this thread to PLS HELP NEED MOTOR LOL
    Any ideas or tips would be great. It HAS TO BE AUTOMATIC!!
    4 stroke snowmobile engines like the Yamaha Phazer are popular for automatic buggies, and should be more available in Canada.
    Aug 2016
    Are we talking older sleds or do you mean the newer style Phazer? I am on a (gasp) budget
    Would a predator 420cc from Harbour freight cut it with a torque converter?
  1. buggy rear help
    By dustertucker in forum Projects in Progress
    Last Post: 11-04-2011, 07:59 PM
  2. FF car to mid-rear buggy
    By Mecrob99 in forum MiniBuggy.net Lounge!
    Last Post: 07-06-2011, 08:15 AM
  3. Buggy with solid rear end
    By Sthib in forum MiniBuggy.net Lounge!
    Last Post: 03-21-2011, 07:55 PM
  4. First buggy build need help with rear end ST2 ng
    By bigsting987 in forum Projects in Progress
    Last Post: 05-04-2010, 03:44 PM
  5. Replies: 16
    Last Post: 03-26-2008, 12:26 PM
