Page 26 of 26 FirstFirst ... 16 24 25 26
Results 251 to 254 of 254
    Re: Yerf ninja build
    Reverse has always been a debatable issue. Installing a FNR box is expensive on some buggy setups, so some builders tend to skip it. My buggy doesn't have it and I really struggled at first, but you tend to learn how to drive and park in ways that avoid reverse. However, my next build is a heavier buggy and I'll need reverse on it.
    Aug 2016
    Leander, TX
    For a reverse I'm thinking a harbor freight ATV winch for $40. I'll need to mount a belt pulley on it somehow, and mount the whole thing on a hinge so i can add tension when I want to reverse, and un-tension the belt for normal operation. The winch goes both ways so would make a good granny gear.
    I really wish I had used an ATV motor.
    I would get a winch with free wheel my self and put a sprocket on it.That way you can keep tension on it.Maybe even be able us it on the same chain as the motor.
    Sep 2008
    Allendale MI
    Have you thought about using a starter motor and a ring gear?
    Justin
    Nowhere near the desert.
  1. My Yerf Dog Spiderbox
    By mikesova in forum Show off your toys in here!
    Last Post: 01-13-2014, 09:08 AM
  2. 900 ninja buggy build
    By buggymane in forum Projects in Progress
    Last Post: 03-18-2013, 11:20 AM
  3. First buggy build . ninja 600 any help or advice welcom
    By xd2cx in forum Projects in Progress
    Last Post: 10-02-2012, 06:13 AM
  4. just got a 600 ninja want to build a rail out of it
    By peterpan in forum MiniBuggy.net Lounge!
    Last Post: 05-02-2010, 11:42 AM
  5. Ninja powered buggy build
    By mdune_100 in forum Projects in Progress
    Last Post: 04-07-2010, 08:50 AM
