Thanks Mikah.
I will check that as I would use rotor purchased from a local shop.
Cheers.
Results 21 to 28 of 28
- Join Date
- Mar 2012
- Location
- Wellington, New Zealand
- Posts
- 508
09-01-2016 06:50 PM
- Join Date
- Jun 2016
- Location
- Wellsville, KS
- Posts
- 15
09-05-2016 08:48 PM
Well, got some more work done but it took me longer than hoped (as is the norm). I probably went a bit overboard with the Brake Caliper modeling, but this is still "fast and sloppy" modeling compared to what we normally do so it's hard to break the habit!
Good news is I now have reverse engineered all the critical pieces so I can design the uprights. The only tricky bits I see right off are getting enough space to get to the wheel hub mount bolts. The caliper mount bracket is nice and tidy with the hub mount flange so should be nice and strong, but I think it might get a little bit tight in there. The pads are a touch wider than the surface of the rotor but they are nicely centered so should work fine, will just wear a little funny!
Also depending on the diameter of the back face of the wheel I may need to run some small (1/4" or so) wheel spacers to ensure clearance.
~Mikah B.
- Join Date
- Jun 2016
- Location
- Wellsville, KS
- Posts
- 15
09-05-2016 08:55 PM
Also, I will use this particular post to start building a library of 3D CAD models to share. All are STEP files and all are use-at-your-own risk!
EMPI 33-Spline 930CV Micro Stub Axle: https://docs.google.com/uc?id=0B-3HP...EZUcGZmRTVNU2s
1993 - 2004 Dodge Intrepid Wheel Hub: https://docs.google.com/uc?id=0B-3HP...HVwVFNHRWVVMDA~Mikah B.
- Join Date
- Mar 2012
- Location
- Posts
- 508
09-05-2016 08:59 PM
Thanks a mil for the files, I will incorporate them in to my build ASAP.
- Join Date
- Jun 2016
- Location
- Wellsville, KS
- Posts
- 15
09-06-2016 02:30 PM
Models are looking great! Thanks for posting those up for download!
- Join Date
- Jun 2016
- Location
- Wellsville, KS
- Posts
- 15
Rear Suspension Design "help please"
By grheathm in forum Projects in ProgressReplies: 7Last Post: 12-22-2012, 06:38 PM -
New here and want to build a "buggy" for my girls. just a few questions
By djlucich in forum How To Do ItReplies: 12Last Post: 12-02-2012, 08:01 PM -
"Spectre" 2-seat "Midi" project
By RoosterBooster in forum Projects in ProgressReplies: 28Last Post: 01-11-2012, 12:39 PM -
Define "mini" buggy
By Nutty4x4 in forum MiniBuggy.net Lounge!Replies: 9Last Post: 04-09-2011, 11:09 AM -
"Trinity" Mini A-Arm buggy I'm building
By TutTech in forum Projects in ProgressReplies: 7Last Post: 07-19-2009, 07:49 PM
